Old 10-31-2022, 09:53 AM
Evasive Evasive is offline
Default Disc conversion
Working on a 64 Catalina and I'm trying to source parts for a front disc conversion. I was told that Scarebird was a good source for the brackets until I learned that he's closing shop and not producing them anymore for the Catalina. What is the next best source for brackets or the whole kit, other than MPB?
Old 10-31-2022, 10:22 AM
Ames.
Old 10-31-2022, 03:15 PM
Wasn't expecting that reply. I'll give Ames a call because I'm not seeing the brackets in the catalog. Thanks for the tip.
Old 10-31-2022, 03:41 PM
Stuart's Avatar
Stuart Stuart is offline
Here's the link in the online Ames catalog for disk brake conversions: https://secure.amesperf.com/qilan/De...A&web_access=Y
Old 11-01-2022, 07:27 PM
I don't think Ames' kit comes with a master cylinder, booster or proportioning valve. I bought Master Power Brakes' kit and it came with everything for my 1964 GP.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 11-01-2022, 07:57 PM
The booster they use is too small for the master.
Is the rotor they use proprietary? no 11" 5 on 5 I know of...
Old 11-05-2022, 09:12 PM
I don't know what they use in the front but the rear were Jeep with the center hole machined bigger. I would think the front are off the shelf .
Old 11-06-2022, 12:28 AM
blueghoast's Avatar
Ames.
Do you have a kit for a 57 chieftan? Thanks.
GT
Old 11-06-2022, 10:34 AM
GT
Yes, we have a few left - they are on the website.
Old 11-09-2022, 01:47 PM
GT182's Avatar
GT182 GT182 is offline
My thoughts are.. if Scarebird doesn't have it, you don't need it. I bought my disc set from him and haven't regretted it at all. Had one problem which was taken care of and from then on, the front disc setup has run perfectly. So much better than those drum brakes ever thought of doing. Best move I ever made concerning the front brakes on my 66 GTO. The second best was not having to change out the front drum brake spindles.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-09-2022, 08:52 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
Did 62 Catalina Ames frt disc
Master power brake booster and master
Stops perfect
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 01-14-2023, 10:48 PM
punisher7's Avatar
punisher7 punisher7 is offline
Stops perfect
Did their master and booster bolt right in or require modification?
Old 01-15-2023, 11:48 PM
Bolted right in no modifications
2008KRE Q16 Winner
