Old 07-30-2022, 05:55 PM
Old Goat Racer's Avatar
Default MASTER CYLINDER NEEDED
Many years ago I took the power booster off my 69 GTO and I believe I put a MC on it that was for Disc brakes without power. Where can I find one ?
Won't make Norwalk otherwise. OGR
Everybody knows somthin.
Nobody knows everything !
Old 07-30-2022, 06:44 PM
Formulabruce's Avatar
Replacement boosters have 2 rods with them. You should be all set for almost any 69 GM car.
Ames has em.
Old 07-30-2022, 06:53 PM
I guess my question wasn't clear ? I need a master cylinder for disc brakes, but no power brakes.
Old 07-30-2022, 07:01 PM
It's been little over 20 years, but the last oem master/manual disc setup I put together for a '68-72 GTO I used a rebuilt manual disc master for a '68 Chevelle manual disc car. I'd bet not something one can order any more at local O'Reillys.
Old 07-30-2022, 07:13 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Maybe this will help. You need a 1" bore master for manual disc brakes.
https://www.chevelles.com/threads/wh...linder.247363/
Old 07-30-2022, 07:15 PM
fyrffytr1's Avatar
https://www.oreillyauto.com/shop/b/b...aster+cylinder
Old 07-30-2022, 09:09 PM
I have an original from a '71 Formula. I am sure it would need to be checked out, gone through though.
Manual disc brake, the tall style Master Cylinder.
Old 07-30-2022, 09:13 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
I believe the MBM MC309 will work for you.
https://mbmbrakes.com/mc309-gm-1967-...ster-cylinder/
MBM description:
GM 1967-1977 Cast Iron with Bleeders
1-1/8" Bore; Deep Hole
9/16" & 1/2" Ports on Left Side with Bleeder Valves
Licensed GM Restoration Part
Exact Copy of Original w/ casting number 5468309
There are a few on line vendors.
Be aware that there will not be a residual valve for the rear drums in this MC. They do recommend the use of an inline residual valve but it is not absolutely necessary and say to use one at your discretion.
I am not sure of the 69 models but according to the 68 service manual all models used a 1-1/8" MC with Disc Brakes
Also, Tuff Stuff Performance has a selection of MCs 1" or 1-1/8" bores with deep or shallow piston holes.
https://www.tuffstuffperformance.com...cylinders.html
Dave
68 GTO
68 LeMans
68 LeMans Convertible
79 Firebird
Old 07-31-2022, 09:10 AM
gman005's Avatar
gman005 gman005 is offline
I used the Right Stuff on my 72.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 07-31-2022, 09:57 PM
fyrffytr1's Avatar
Do you have 4 wheel disc brakes or front disc, rear drum?
Old 08-01-2022, 11:37 AM
FD RD
Old 08-01-2022, 02:50 PM
gto4ben gto4ben is online now
These may help in your search.
Name:	67-70 Master Cylinder Usage.jpg
ID:	595528   Click image for larger version
Name:	68-70 Master Cylinder Usage.jpg
Old 08-04-2022, 06:40 PM
Found a MC at auto zone, NM1489. Doesn't look original but installed it does have a firm brake pedal.
Off to Norwalk !
Old 08-05-2022, 04:14 PM
dmorg1's Avatar
Off to Norwalk !
Old Goat Racer,
Great that you found one local.
Just for my future reference, did this MC have the residual valve in the rear port?
Thanks,
Dave
68 GTO
68 LeMans
79 Firebird
Old 08-06-2022, 02:52 PM
Originally Posted by dmorg1 View Post
Old Goat Racer,
Thanks,
Dave
Sorry, but I don't know that answer.
