WTB Starter Bracket
Looking for the starter bracket/brace that mounts on the front of the starter and bolts to the block under the oil fill tube. Mine is missing.
I wish it was that easy, but the OHC bracket is unique and no one reproduces them.
I didn't realize you had a OHC 6, probably good to make that known in your request. I just was looking through new posts and didn't realize it was in the OHC 6 section.
VHTF...
These brackets are almost as scarce as the Bell-Housing Dust Cover.
Over the years I guess they just get left out due to what a PITA they are to re-install. I'll look in the bins over the weekend and see if I have any left.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:13 AM. |
Sorry no spares.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks for looking Jeff. I see it looks like you finally landed a inspection plate. Maybe your luck will run over my way.
Still looking.
Still looking
Bump
FWIW...
Not sure if these are of any use, but if you decide to try and make something they may.
Thank you. Certainly an option. Doesn’t look too hard to fabricate.
Still looking.
Bumps
I have the original bracket in good condition. photo sowing 2-items on right ought be relevant.
Yes that looks correct. PM me cost for shipping to 24060. Thanks
The Following User Says Thank You to Hokie1984 For This Useful Post: | ||
