Old 12-17-2021, 12:55 PM
misterp266's Avatar
Default Roots blown fuel supply
Opinions wanted especially from people actually running a roots blower on the street.
Street driving only!
Carbureted 433” w/671 blower. Shooting for 10psi maximum boost. 330cfm SD ported Edelbrock heads. Cam is a Spotts specked 248/258 @ .050 .541I .541E.
Don’t want to over build for street use only. Was thinking of a 140 lbs/hr Aeromotive SS pump pn11213 with a return style regulator pn13212. 3/8” lines both ways. I already have the regulator.
" Darksiders Rule "
Old 12-17-2021, 01:22 PM
GTOGEORGE's Avatar
I don’t drive my car on the street….. I could my engine is more then capable of being street drive BUT what I do know from experience is BIGGER is always better as much as you may not think so people always eventually always want to step up.
GTO George
Old 12-17-2021, 07:15 PM
Stan Weiss's Avatar
Let get the specs correct 140 GPH, as I would not run a 140 lbs/hr on an N/A 433 ci engine. What fuel do you plan on running?
Stan
Pontiac Pump Gas List
Old 12-17-2021, 07:52 PM
opeliac opeliac is offline
GTO George
Bigger fuel pumps bring problems when street driving...So, bigger isnt always better...
His combo doesnt sound like it'll need a ton of fuel.
Old 12-17-2021, 08:22 PM
GTOGEORGE's Avatar
OK……………….LOL!
GTO George
Old 12-17-2021, 09:08 PM
misterp266's Avatar
Misprint, yes 140 GPH.
93 Octane. Static will be about 7.9:1. Trying to stay safe.
I’m retired George. Just trying to build one last fun car, will never be able to afford “stepping up”, nor do I want to...
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
Old 12-17-2021, 09:22 PM
GTOGEORGE's Avatar
We’ll see!
GTO George
Old 12-17-2021, 11:14 PM
OK……………….LOL!
GTO George
I'm not sure what was so funny...Or, is this just another situation where you dont have a clue about the topic?
Old 12-18-2021, 05:21 PM
blueghoast's Avatar
With the 3/8 lines both way's you'll be fine even at 10 pounds.
The return line is a good way to go and will make things even better.
So go for it.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 05-14-2022, 01:58 PM
ERIC AULL ERIC AULL is offline
This is what I did.....works well, no problems 505 cu in 871 750 QFTx2 use a bypass regulator with return Aeromotive A-1000 pump back near gas tank......#8 to engine...#6 return. You won't need this much. I run 7lbs or fuel pressure.....8lbs boost......Sorry if this reply is late, just saw this post. How is your project coming? Eric
ID:	590836   Click image for larger version
Old 05-15-2022, 10:38 AM
misterp266's Avatar
Thanks Eric. I thought the A-1000 would be overkill for my setup so went with the SS pump. I’m also using QFT 750’s. Black.
I work out of a small one car garage. I’m retired and money has gotten a lot tighter these days so progress is slow but I enjoy the process. Your car is nicely done. I’m sure you’re enjoying it!
" Darksiders Rule "
