Old 04-20-2021, 10:38 PM
RedDirtRoad RedDirtRoad is offline
Power washed the bottom floors and removed the factory applied Ziebart rustproofing/undercoating.
I am grateful the original owner decided to get this done. I think it saved the car since it’s rock solid with no rust whatsoever
But I also regret it because it’s an ugly nasty job to remove.
Spent a day removing the undercoating and plan on dusting new red oxide primer soon .
ID:	565085   Click image for larger version
ID:	565086   Click image for larger version
ID:	565087   Click image for larger version
The Following User Says Thank You to RedDirtRoad For This Useful Post:
Old 04-21-2021, 07:16 AM
77 Canamman's Avatar
That underbelly is fantastic..
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 04-21-2021, 08:43 AM
TAKerry TAKerry is offline
That floor looks fantastic! I havent seen too many that look like that.
Old 04-21-2021, 09:34 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
What brand rotisserie?
Skip Fix
Old 12-22-2021, 06:37 PM
Been a while since i posted but things are moving along slow and steady
The sub frame is complete and engine installed
Old 12-22-2021, 08:19 PM
I guess my photos didn’t get embedded
Old 12-23-2021, 01:16 PM
Must be a clitch. I can see the photos on my PC but not on my phone
ID:	580457   Click image for larger version
ID:	580458   Click image for larger version
ID:	580459   Click image for larger version
Old 12-23-2021, 01:43 PM
Under car is stripped of undercoating, cleaned and original red oxide primer now showing. Original exhaust system, converter and mufflers still in great shape. Rear axle cleaned and detailed
ID:	580447   Click image for larger version
ID:	580449   Click image for larger version
ID:	580450   Click image for larger version
ID:	580452   Click image for larger version
Old 12-23-2021, 02:51 PM
Mike Davis's Avatar
Looks really good.
Keep us posted on the progress.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 12-23-2021, 06:30 PM
77 TRASHCAN's Avatar
What are you using for the exhaust, behind the converter???
I've read about some of the exhaust tubing being double walled, and being restrictive inside when the tubing was bent???
I'm also interested in how the 2 pipes are hooked together behind the converter. Wondering if these new pipes are better manufactured than original, AND less restrictive???
Now that I just read about re-using the original exhaust, disregard my questions...
Shut it off
Shut it off
Old 12-24-2021, 12:37 PM
SD455DJ SD455DJ is offline
RedDirtRoad, You are doing a kick-a$$ job on the resto. It looks amazing so far! Can't wait to see it finished...this spring???
Dennis
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 12-24-2021, 03:58 PM
Thanks Dennis
The car is further along then the pics show
I just been too lazy to go through all my pics and post
More pics coming soon
Old 12-24-2021, 05:04 PM
trishieldchief's Avatar
Your TA is in amazing rustfree condition, where did this car live its early years when it was on the road?
Rich Johns
www.purestockauto.com
1970 GSX Stage 1 Auto 3.64 # 603 of 678 12.44@109.73 mph 2011 Buick GS Nats Pure Stock, 12.71@110.64 mph PSMCDR 2011
1970 GS Stage 1 Convertible Auto 3:64 12.71@109.15 mph PSMCDR 2009
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 12-24-2021, 06:56 PM
It was in PA. It only has 26K original miles so most likely wasn’t driven in the winter on salty roads
It was in a garage all its life as well. When the owner passed away the family move the car outside and the past five years has taken a toll on it
Old 12-31-2021, 04:01 PM
Cleaned up the radiator overflow jar with acid.Looks new again. Cleaned cap on buffing wheel and reapplied the blue paint. Cleaned up the spring clamps and re dipped in green zinc phosphate. Stripped and refinished bracket in black phosphate.
ID:	581016   Click image for larger version
ID:	581017   Click image for larger version
ID:	581018   Click image for larger version
ID:	581019   Click image for larger version
Old 12-31-2021, 04:08 PM
Stripped all the under coating off the plastic duct for the air cleaner and sent to my buddy that works in the plastics industry. He refinished then to look new again.
ID:	581021   Click image for larger version
ID:	581022   Click image for larger version
ID:	581023   Click image for larger version
ID:	581024   Click image for larger version
The Following 2 Users Say Thank You to RedDirtRoad For This Useful Post:
Old 12-31-2021, 04:23 PM
All hoses, electrical wiring and fluids are complete.
Hopefully I can turn the key next week and fire it up
ID:	581031   Click image for larger version
ID:	581032   Click image for larger version
ID:	581033   Click image for larger version
  #38
Old 12-31-2021, 04:31 PM
Car was painted original Marti Blue last month and paint is finally gassing out so I can apply the decals soon. I begun putting parts back on the car like tail lights, spoiler, door handles and locks, weatherstripping, etc. but cant put the front clip on till I fire up the car and make sure no issues first.
ID:	581035   Click image for larger version
ID:	581036   Click image for larger version
ID:	581037   Click image for larger version
ID:	581038   Click image for larger version
  #39
Old 12-31-2021, 04:51 PM
Spent a good long week to disassemble the front bumper and fascia.
I scored NOS grilles and a NOS red arrowhead too. Not much more then buying repro parts actually.
I found some cool inspection marks too on the inner bumper and also the headlight assm. looked like the date and 3rd shift maybe?
ID:	581042   Click image for larger version
ID:	581043   Click image for larger version
ID:	581044   Click image for larger version
ID:	581045   Click image for larger version
  #40
Old 01-01-2022, 06:21 AM
Aus78Formula Aus78Formula is offline
Nice detail pics
