Where to buy procharger
I’m thinking about a supercharger where is the best place to purchase it? The most complete kit to put on a traditional Pontiac 455. Thanks.
Probably Luhn Performance. They can supply their bracket as well as the head unit.
Procharger kit
http://www.luhnperformance.com/ati.html Vortech kit http://www.luhnperformance.com/vortech.html Don’t overlook the Vortech YSI. It’s a great blower. A friend ran one on his Buick 455 for years trouble free.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
A T-Trim Vortech Supercharger made 862 Dyno HP on Steve Morris Dyno. 13 psi boost
A YSi will make more HP possibly as much as 1000 real hp on a dyno. Brian Hedrick ran a Procharger on his Firebird for years, Actually several Procharger units. Without a really good intercooler on the front of the car, they make a lot of heat. Not needed with other methods of cooling the charge, for a drag only deal. (Water to Air intercooler mounted in the passenger seat location.) Tom V. How much power do you want to make?
In order to get optimum numbers you WILL need either open headers or a free flowing exhaust among other things, So your numbers WILL very up or down…….just saying!
GTO George |
The Following User Says Thank You to GTOGEORGE For This Useful Post: | ||
I remember a long time ago when i was running 8.90's on racing gas i switched to 2 1/4" headers from 2" and picked up a little bit over 2 tenths no other changes!
GTO George |
Since header tubes measurement is based on tube outside diameter, and even the thinest / lightest header wall thickness would probably be .060", a 2.0" header tube is actually 1-7/8" internal diameter. A 2.25" header tube is 2-1/8" internal diameter.
So you made a big change in the flow capability of your exhaust Zoomies. Tom V.
.250"
LOL!! Hence the 2" to 2 1/4" increasement GTO George |
Smart move there.
Tom V.
GTO George |
A long time ago B & M had one of the BEST Real Life numbers book on Supercharging, it should the HP, BOOST, TORQUE numbers of different heads, header sizes, camshafts, different blower speeds......I wish it was still available!
GTO George |
You can PM me the spec's if you like Thanks. If not I under stand. GT |
It is area of inside diameter the pipe that counts.. Going from 1 7/8" to 2 1/8" is 128.44% increase Going form 2" to 2 1/4" is 126.56% increase. Close but no cigar. Stan
Stan
You have to assume that the Drive losses would be high to drive that BDS unit.
The drive losses on a centrifugal (Procharger) supercharger are lower for sure. The Original Thread Post #1 was discussing a Procharger Supercharger. Tom V.
GTO George |
GTO George |
Intake 300* 272* .440" 110 .022" cold .028" Hot Exhaust 316* 288* .440" .024" cold .030" Hot Intake opens at 30* BTDC closes 62* ABDC Exhaust opens at 78* BBDC closes 30* ATDC Overlap is 60* Not the perfect cam but i needed one and DCI had it on laying around. Thanks Don! GTO George |
About 5 degrees at .050 smaller than the camshaft Jimmy Keen ran in his 347 cid engine when he was the
1998 National Super Street Champion. He ran his engine to 9,000 rpm every pass with the two speed glide trans. (He went thru a lot of Power Glide Trans. Sometime 3 in a week-end of racing). He had about a .786 lift at the valve. Agree, your cam is not the perfect camshaft but will work until you could find the right one. Jimmy's Cams were ground by Harold B. He was racing against the best at the time, Billy Glidden, in Super Street for a National Championship 1998. You are Bracket Racing. But if the camshaft does the job go for it. Don did you a favor. And it should be close enough for a bracket engine. By the way, Jimmy could run 7.50s with his 347 cid Mustang. Just like Brian Hedrick did with his Procharger car. And the thread IS about a guy wanting to buy a Procharger for his PONTIAC engine. Talk to Brian Hedrick grandam1979. If you pm me I will get his cell number off my phone to you. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 12-05-2021 at 10:54 PM. |
I’m thinking Brian only ran mid 8’s at 13 lbs of boost!
GTO George |
Thread Tools | |
Display Modes | |
