Old 01-23-2022, 01:22 PM
Tfrias Tfrias is offline
Default 66 Catalina For Sale
389, TH400, AC, 4W Disc, 1800 miles on car since I completed chassis off rebuild. Full restroation picture documentation upon request. Must see. Beautiful Pontiac Widetrac !!! Motivated to sell, will negotiate.
Please inquire if interested.Thanks, TODD
42K
Oldbluehusky@yahoo.com
ID:	582503   Click image for larger version
ID:	582504   Click image for larger version
ID:	582505   Click image for larger version
ID:	582506   Click image for larger version
Old 01-27-2022, 12:59 PM
Did I mention complete frame off ? Fully powder coated chassis, suspension, core support, wheel houses, and interior trim bits. Have a look !!!
Name:	Engine install 001.JPG
ID:	582835   Click image for larger version
Name:	Engine install 003.JPG
ID:	582836   Click image for larger version
Name:	Engine install 006.JPG
ID:	582837   Click image for larger version
Name:	Engine install 011.JPG
ID:	582838   Click image for larger version
Old 01-27-2022, 01:14 PM
Stuart's Avatar
Stuart Stuart is offline
Please include your location, per board rules.
Old 01-27-2022, 01:31 PM
Morning Stuart,
Northern Nevada South of Reno.
Old 01-29-2022, 06:06 PM
Default Small Part List
Small parts list
Original 389 CID
Bore .030/Hone/deck block/align
Grind crank .010 Clevite MS483G
Scat balancer D-80020
Resize rods Clevite CB758P
Pistons & align KB370 +.030/Sealed Power E253K
Melling oil pump 10540
Cam bearings Durabond P4
Comp cam 51-2223-4
Comp cam 7112 Timing Set
Comp Rockers 1251-16
Comp cam lifters 852-16
Comp cams 988-16 springs
ReCon OEM heads bronze guides/SI Stainless valves/Viton metal clad seals/Bowl port/Gasket match surface
Edelbrock 7156 RPM Performer
Holley 0-8677BK Ultra Street Avenger 770 CFM Tuned
Dougs Headers D-521-R
MSD 8563 Distributor
MSD 6425 6AL Digital Box
MSD 31193 Wires
MSD 8203 Coil
ARP 190-3602 Head
ARP 190-6001 Con Rod
ARP 194-5401 Main Stud
ARP 594-9801 Engine
ARP 200-2904 Flex Plate
Northern Aluminum Radiator/Duel Spal 3500 CFM Fans
Original TH-400
All new:
KB3400D Mok w/Borg 400/65-up
34903 Bushing kit 400/65-up
34402A Roller lower 400/4180E
34418X Sprag intermediate 400/4I
34325 Band front 400/425/4180E
400-1-2 Performance kit 400/65-up
38820 Modular red str small g
5A-100Solinoid valve body 400/6
K349007B Bearing kit torr 400/4180
34661 Filter 400 (e) 64-67
34501A Washer output 4 tang 400
34401 Washer center support dru
GM3HD Torque converter
Trans mount
Flow-Master 817412 Stainless Exhaust
Ames PR207D Front disc conversion/Rear Scar-bird Mounts NAPA 4885776 Hats/SE4689-90 Calipers
CPP 6474BB-7 Master/Booster
AND THE LIST GOES ON… .Want more info ?? OLDBLUEHUSKY@YAHOO.COM or shoot a PM for Phone number.
Thanks, TODD
ID:	583163   Click image for larger version
ID:	583164   Click image for larger version
ID:	583165   Click image for larger version
ID:	583166   Click image for larger version
