Old 05-18-2022, 04:49 PM
F1147D's Avatar
F1147D F1147D is offline
Default 70 GTO parts
70 GTO PARTS
These are all left over from my restoration price doesn’t include shipping. If you are interested my email is Tim_Larsen76@hotmail.com
Single groove crank pulley- $15
480509 XS
Rear bumper brackets frame to inner brackets. Left is bent a little. -$20
Fan clutch-$20
477957-PC
Harmonic balancer-$15
Trunk latch assembly missing one bolt-$10
Air cleaner elbow (x2) $5 each
Aftermarket front park light/turn signal sockets - $5
Rear view mirror bracket and black cover- $15
New aftermarket window cranks -$20
Rear seat ash tray -$10
Ignition coil bolt and strap (AMK G-7638)- $10
Throttle bracket to intake (AMK G-7628) -$10
Seat side panel screws (AMK- G-6656) - $10
Seat back panel screws (AMK G-6654) -$10
Water neck bolt and hardware (AMK G-7594)- $10
Hood scoop insert fasteners (AMK G-7410)- $10
Console bracket screw kit (inline tube #INL12497)- $10
Heater hose clam kit (inline tube #INL10500)- $10
Valley pan bolts (inline tube #INL10128)-$10
Radiator hose clamps (#INL11303)
Starter wire heat shield non ram air- $10
Hood release assembly (release lever attach point is bent)
Console lid hinge -$10
Headlight bulb retaining ring - $5
Air cleaner to valve cover vent tube - $10
Coil (unknown condition) 238 BR - $10
Center console mounting bracket - $10
Fuel pump (unknown condition)
Headlamp housing - $10
ID:	591095   Click image for larger version
ID:	591096   Click image for larger version
ID:	591097   Click image for larger version
ID:	591098   Click image for larger version
Old 05-18-2022, 04:52 PM
F1147D's Avatar
Pictures
ID:	591100   Click image for larger version
ID:	591101   Click image for larger version
ID:	591102   Click image for larger version
ID:	591104   Click image for larger version
Old 05-23-2022, 04:51 PM
F1147D's Avatar
Fan clutch and vent tube sold. I am open to offers. Thanks
Old 05-31-2022, 12:28 PM
F1147D's Avatar
Default GTO PARTS
GTO PARTS
Single groove crank pulley- $10
480509 XS
Harmonic balancer-$10
Rear view mirror bracket and black cover- $10
New aftermarket window cranks -$15
Rear seat ash tray -$5
Ignition coil bolt and strap (AMK G-7638)- $5
Throttle bracket to intake (AMK G-7628) -$5
Seat side panel screws (AMK- G-6656) - $5
Seat back panel screws (AMK G-6654) -$5
Water neck bolt and hardware (AMK G-7594)- $5
Hood scoop insert fasteners (AMK G-7410)- $5
Console bracket screw kit (inline tube #INL12497)- $5
Valley pan bolts (inline tube #INL10128)-$5
Hood release assembly (release lever attach point is bent) $5
Old 06-14-2022, 10:03 PM
F1147D's Avatar
Still available
Old 06-14-2022, 10:26 PM
4dblnkldude's Avatar
Ill take the crank pulley where do I send cash?
Old 06-15-2022, 08:18 AM
F1147D's Avatar
Message sent
Old 06-15-2022, 11:35 AM
kk68's Avatar
kk68 kk68 is offline
I'll take the 2 air cleaner elbows. Email sent.
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 06-17-2022, 01:37 PM
F1147D's Avatar
Default 1970 GTO PARTS
Still available. If anyone is interested I am open to hearing an offer for everything.
Parts in Bold are new in package
Radiator hose clamps (#INL11303) $10
Fuel pump (unknown condition) $10
Old 06-22-2022, 08:58 PM
F1147D's Avatar
Old 06-22-2022, 09:07 PM
Thanks for the pulley!!
Old 06-24-2022, 05:52 PM
F1147D's Avatar
Have pictures if you want to see something first.
Old 06-29-2022, 01:51 PM
F1147D's Avatar
Default 1970 GTO parts
Rear bumper brackets frame to inner brackets. Left is bent a little. -$15
Rear view mirror bracket and black cover- $8
New aftermarket window cranks -$10
Rear seat ash tray -$3
Ignition coil bolt and strap (AMK G-7638)- $3
Throttle bracket to intake (AMK G-7628) -$3
Seat side panel screws (AMK- G-6656) - $3
Seat back panel screws (AMK G-6654) -$3
Water neck bolt and hardware (AMK G-7594)- $3
Hood scoop insert fasteners (AMK G-7410)- $3
Console bracket screw kit (inline tube #INL12497)- $3
Heater hose clam kit (inline tube #INL10500)- $5
Valley pan bolts (inline tube #INL10128)-$3
Radiator hose clamps (#INL11303) $5
Starter wire heat shield non ram air- $5
Console lid hinge -$5
Headlight bulb retaining ring - $3
Center console mounting bracket - $5
Fuel pump (unknown condition) $5
Headlamp housing - $5
Old 07-06-2022, 10:06 AM
F1147D's Avatar
Still available
Old 08-17-2022, 01:51 PM
F1147D's Avatar
Default Parts for sale
