Intake manifold.
Looking for pictures of a 79 Olds 403 Air condition T/A OEM intake manifold. Concern is where the DS-TVS switch goes. The intake on this car only has one hole up front by the water neck and I have been using it for the water temp sender. Having a hard time finding out what’s OEM. The car has a K in the Vin and believe it’s a federal standard not high alt. Also any vacuum line information off manifold and carb is appreciated. Wanting to put the car back to factory specs even emissions.
Thanks!
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
They still use the same 76-80 #16 intake but the cast bosses are drilled and tapped as required. This intake from a '79 403 has all 3 fittings for the front coolant passage but only one of the runners behind the carb.
Do you have the emission label for your engine version and a similar carb? Do you need the TVS or even have smog? Or just High-Altitude. If you don't need it, or have it, I'd select the more basic version of emissions and copy that label, depends what's required. 403 16 intake1 by Aus78Formula, on Flickr |
No good?
Thread Tools | |
Display Modes | |
