Old 07-25-2022, 06:16 AM
461-69bird's Avatar
461-69bird 461-69bird is offline
Default Cylinder marks
disassembling the engine after my roller lifter failure. Are these marks on the cylinder bores ok or should I be concerned? They are on all 8 cylinders on the crank side. I can only just feel the main line with my nail.
ID:	594943   Click image for larger version
69 Firebird
472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123
Old 07-25-2022, 06:25 AM
25stevem's Avatar
25stevem 25stevem is offline
I had the same thing take place when I had the needles fail in one of my lifters from the lash opening up, before I really new how to set a poly lock .
Those scratches are from the broken very ground up pieces of the needles getting up in there.
The problem I found and what concerneds me far more then the scratches on the walls was that I found some of the Pistons still had some of that ground up very hard steel imbedded in the piston skirts!
I know it's not what you want to here, but I would disassemble the whole motor to check this.
This will also allow you to flush out the oil galleys and Crank passages where more of that steel grit could hanging out.
Your going to want to re-ring it anyway because now the Moly on the face of both compression rings is scratched up also unfortunately.
Thank God for roller lifters these days that use a bushing and do away with the needles!
PS.
Your oil pump is likely scratched up on the inside also.
I do stuff for reasons.
Old 07-25-2022, 08:02 AM
461-69bird's Avatar
Steve, did you have to hone the bores again? Is the oil pump no good now, should it be replaced?
69 Firebird
Old 07-25-2022, 08:05 AM
scott70's Avatar
scott70 scott70 is offline
How many miles? I've torn engines down and seen normal skirt marks like that.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 07-25-2022, 09:04 AM
Tom Vaught's Avatar
Boost Engineer
Either way it means trash or dirt went thru the cylinders at some point in time to score
the cylinders like that.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 07-25-2022, 09:29 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I had a roller lifter mishap many years ago and it embedded tiny pieces of metal in a few of the skirts.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 07-25-2022, 11:33 AM
25stevem's Avatar
I would flexhone each Bore to the tune of 3 up & down passes.
Your pump is likely still good but you will want to take it apart and flush it out so to be sure there's nothing in there to keep the check ball unseated.
Old 07-25-2022, 12:57 PM
461-69bird's Avatar
Thanks guys, I'll carry on taking it apart and add to my parts list.
I'm coming to America in September so I'll bring back as much as possible to save on shipping.
69 Firebird
Old 07-25-2022, 04:22 PM
25stevem's Avatar
Scott70 I need to ask you a question and this I do not to pick on you, but to get you thinking straight.
Pistons are Aluminum and in the case of our Pontiacs the cylinder walls are cast iron.
So how would a softer metal then cast iron make for these kind of scratches you have commented on seeing before?
There are only two ways for this to take place.
1) due to the rings and oil ring rails not being prepped right, but scratches made in that way would not extend to the bottom of the bore as in the OPs photos.
2) metal grit and crap in the motor will produce what’s seen in the OPs photos, or a combination of this and number 1 can take place also.
Old 08-03-2022, 02:04 PM
461-69bird's Avatar
Default More pics after disassembly
Need to get the block and crank cleaned. I take it the oil gallery plugs need to come out beforehand.
Bearings look really good, crank isn't damaged. Been using VR1 20/50 as per Shakers instructions.
Does the thrust bearing look ok? Didn't have any excessive end play.
Think I was told before but on the splayed caps, is it ok that the centre 2 studs were loose once I undid the nuts? I could unscrew them by hand.
ID:	595684   Click image for larger version
ID:	595685   Click image for larger version
ID:	595686   Click image for larger version
ID:	595687   Click image for larger version
69 Firebird
