Convertor spacing
I just installed my Continental convertor on my 461 and im getting .118 thousands spacing between the flexplate and my convertor pads with it pushed tight to the pump. I have heard .125 thousands is ideal. Can I run that or do i need to fix somthing here?
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
Do you have the stock thin shim plate between the crank flange and the flexplate ?
I do stuff for reasons. |
No, I didn't use it. I do have a sfi flexplate I picked up from butler, I forget the brand.
Im .007 from ideal according to some sources, I watched a vid performance transmission put out reccomending 1/16 but that seems way to tight. Im just a hair under 1/8 now.
You should be good with those number. They recommend .085-.125 spacing.
From what I understand the measurement is suppose to be 1/8" to 3/16". Anything more than 3/16" gets shims installed to bring back into spec. I know guys who have installed with spacing around .090 and had no issues. I would agree .007 less, that you'll be fine. Make sure the converter snout fits into the crank properly once installed. You can put a bit of grease on the snout doesn't hurt. You can spin the converter and make sure there is no binding before bolting to the flex-plate.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
As long as the converter pulls away from the front pump when bolted up it is OK. Doesn't need to be an exact number
