Old 08-19-2022, 01:25 AM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default disc/drum brake (non-power assist) question...
Think I may have figured it out.....but looking for input...
73 bird with manual brakes.....and I want to keep it that way...
On the rear...new wheel cylinders...linings spring and adjuster kits....
on the front....reman calipers and new pads...
I decided to try semi-metallic pads and shoes..
After driving several miles......the brakes start to feel like they are dragging.....after several light applications.....I have a hand held temperature indicator....and it seems that the front rotors are getting way hot too fast..like 180 degrees...and right side hotter than left by 20 degrees....
I suspect front flex brake hoses....so that will be this weekends job...
The other thing that comes to mind is master cylinder push rod hanging up.....
Once the cars sits for a while it rolls normally..
Old 08-19-2022, 09:41 AM
Originally Posted by Green Hornet View Post
...The other thing that comes to mind is master cylinder push rod hanging up...
there is your issue.
Old 08-19-2022, 02:49 PM
I'm not sure if these are adjustable, but my 55 Chevy had the exact problem and it was the pushrod to master. I needed to go under dash and adjust it back about 1/4" as it was pushing on the plunger of master cylinder.
Old 08-29-2022, 04:11 PM
I think the MC was the problem...
ID:	597457   Click image for larger version
