Old 09-29-2022, 07:11 PM
tooski tooski is offline
Default More on pushrod length
After searching and reading threads n posts on pushrod geometry I still don't have a definitive answer what to go with.
I did the Straub method. Then rolled the engine over with the Straub method pushrod, and then with a stock. The 'Straub' pushrod is about 3/8" longer with a very narrow pattern close to the exhaust side. Stock is wider, but centered.
ID:	599565   Click image for larger version
ID:	599566   Click image for larger version
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 09-29-2022, 08:10 PM
AG's Avatar
AG AG is online now
You should use the length that gives the best pattern (stock length) even though it is a different length than using the Straub method. I always start with the Straub method and adjust as necessary to get the best pattern.
Old 09-29-2022, 10:14 PM
77 TRASHCAN's Avatar
Frank, tell us more about this engine?!
Shut it off
Shut it off
Old 09-30-2022, 12:07 AM
Default Engine
400 +.030. block decked .025 for zero deck with forged trw/speed pro/sealed power pistons. Kre 290 74 cc heads. 10.14 CR. HO Racing HC-02 cam 231/243 @ .050. HS 1.65 rocker arms ~ .515 lift. T2/750DP.
Frank M.
75 Firebird
Old 09-30-2022, 12:15 AM
The question would be: "Which is the best pattern?" Some of the archived threads I've read state the narrowest pattern even if it is off center. Others state as centered as possible even if it is not the narrowest.I could go with a pr half way between stock and the Straub. that would narrow up the stock looking pattern and move the Straub pattern closer to center.
Frank M.
75 Firebird
Old 09-30-2022, 12:45 AM
Cool!!!
That dog should hunt!!!!
Shut it off
Shut it off
