Old 07-04-2023, 08:37 PM
nbn nbn is offline
Default 73 gauge dilemma
Working on righting the wrongs done to this car before we got it.
Replacing all of the wiring with new M&H harnesses.
The fuel and volt gauges are not original to this car.
The harness has plugs for each gauge. Clearly, the gauges do not have the plug receiver. Are the receivers available, or do I need to snip the plugs off the harness and add ring terminals?
Which wire goes to which stud?
ID:	615377   Click image for larger version
Old 07-04-2023, 09:27 PM
Don't know if they make the fittings?
Here is a pic from assembly manual, if your harness has the plug-ins like these can determine which wires go where.
Old 07-04-2023, 10:10 PM
nbn nbn is offline
Awesome! I don't know why I didn't look in my manual. Exactly what I was looking for.
Crossing my fingers that I can find the tabs in the next few days. If not I'll make something work!
Old 07-05-2023, 02:28 AM
Held for Ransom's Avatar
Here's my '74...
ID:	615392   Click image for larger version
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 07-05-2023, 09:18 AM
nbn nbn is offline
Here's my '74...
Color photos help the cause. Thank you.
Old 07-05-2023, 09:53 PM
cnc's Avatar
cnc cnc is offline
HFR’s is the same as my 73…dam pic is upside down….sorry not a great pic
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
The Following User Says Thank You to cnc For This Useful Post:
Old 07-10-2023, 08:33 PM
nbn nbn is offline
In case anyone is concerned, I've found a guy local to me that had a grungy but complete gauge pod for use as parts......
On to the next battle!
The Following User Says Thank You to nbn For This Useful Post:
