Old 09-22-2022, 10:27 AM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Default Clutch Linkage Change
I am looking to "upgrade" my `79 Firebird's clutch system starting with the linkage. I'd like to go rod ends on everything. I'm also thinking of going hydraulic.
I haven't driven the car since I purchased my `08 Corvette mainly due to being spoiled with it's hydraulic clutch. Before I "got spoiled" I didn't think much about how hard it was to push that clutch pedal.
What is your experience with rod ends. Was it a drastic change from the factory linkage? I would imagine it would be. How about going hydraulic as well?
Thanks -
Jamie
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 09-22-2022, 07:17 PM
george kujanski's Avatar
I added rod ends to my linkage because I had breakage issues in the past.
Bought a spare pedal rod from Ames, welded appropriate bolts to the ends, and added the rod ends. Works smoothly now. Going to replace the lower rod when I change my clutch also.
George
Old 09-23-2022, 08:39 AM
Good to hear. That's what I'm going for. Breakage is what I fear. The way that those parts wear, I'm guessing it's just a matter of time before my clutch pedal hits the floor and I'm rear ending someone in traffic because I wasn't able to yank the shifter out of gear to neutral. I'm also looking for smother operation.
08 Corvette - Base
Old 09-23-2022, 10:05 PM
sp4spd's Avatar
sp4spd sp4spd is offline
Lots of options for Ball joint type linkage parts in the McMaster-carr catalog.. I used some of these for my Buick GS 455 4 speed linkage. Worked very well!
https://www.mcmaster.com/rod-ends/
Scott
74 Firebird Formula 400 4speed
70 Buick GS455 4 speed
Old 09-24-2022, 09:13 AM
Formulas Formulas is offline
the stock clutch pedal linkage in my estimation has an abundant amount of travel with 1 inch free play and approx 3 inch of over travel at the bottom
ive always wondered what welding the original pedal hole shut then re'drill a new hole just above it would be like with ball end links
the new hole would decrease pedal effort and soak up a bit of travel, before the OMG crowd has a heart attack the new hole could be just a bit above the old one barely effecting anything but make a small and CHEAP change in pedal feel
way back in the early 90's i welded mine shut because it was elongated BUT i made every attempt to re'drill on center of original hole
also if your crafty you could make your own lower adjusment link with a rod end and a long 3/8 bolt cut and groomed properly
Old 09-24-2022, 11:14 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
There was a company years ago i bought a set from that had rod ends-Probably listed for a Camaro. never used it on the shelf in the shop somewhere.
Skip Fix
Old 09-24-2022, 07:37 PM
ecklers.com
Old 09-24-2022, 09:45 PM
Skip Fix's Avatar
i stink this was the company
https://www.speeddirect.com/clutch-linkage
Skip Fix
Old 09-24-2022, 10:03 PM
The factory linkage works well - when it is new. Redrilling the pedal sounds like a good idea.
Old 09-26-2022, 11:31 AM
HWYSTR455's Avatar
I use the SpeedDirect stuff, they have the rods pre-bent and everything, and not expensive.
I drill a new hole in the Z-bar too, to make the throw ratio higher. That way it takes less pedal travel, and can get the brake & clutch pedals very close to each other, if not completely even.
Don't skimp on the pedal's or the Z-bar pivot points, those areas wear an can cause binds that will bend an OE rod in a heartbeat.
If you can, I say stick to mechanical linkage, less to go wrong. Just keep it 'fresh' and it will serve you well.
Old 09-27-2022, 11:35 AM
jhein's Avatar
jhein jhein is offline
Is the linkage identical for a Firebird and Camaro?
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 09-27-2022, 01:12 PM
HWYSTR455's Avatar
I'm using their' kit on my 71 'bird, so can say for sure it works.
Old 09-27-2022, 01:31 PM
jhein's Avatar
Thanks, I'm gonna get the kit.
Old 09-27-2022, 02:53 PM
Rugratman's Avatar
Rugratman Rugratman is offline
I did not get these on Amazon. There was a Chevelle supplier who made them. Camaro's too.
Look into these.
https://www.amazon.com/SpeedDirect-R.../dp/B014HHQ2F8
I was very happy with mine. Adjustments over the years was great.
........I'm just learning as I go.......
Old 09-29-2022, 02:52 PM
Thanks for all the responses! I'll go with the SpeedDirect stuff!
08 Corvette - Base
Old 10-04-2022, 11:16 AM
I'm very interesting in getting the SpeedDirect kit. So you have that on your `71 TA? It says Camaro on their website which I'm pretty sure works on Firebird too.
08 Corvette - Base
Old 10-04-2022, 11:25 AM
HWYSTR455's Avatar
Yes.
It's in the paint shop, but I had it all assembled with a TKO600 and it worked perfectly. Smooth, even, and with the z-bar mod, fast/short throw. And I worked it at minimum 100 strokes.
Old 10-04-2022, 11:29 AM
Yes.
That's inspiring. I am going to order it this morning.
08 Corvette - Base
Old 10-04-2022, 10:28 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Yes.
Curious hwy- what is the zbar mod that shortens the throw?
Old 10-05-2022, 01:30 PM
Joe-Touring Joe-Touring is offline
Another way to go about this is to use this clutch fork:
https://www.speedwaymotors.com/Speed...ork,37080.html
That will allow you to replace the ball and socket connection on the OEM clutch fork. This means you don’t need the spring to hold the fork to the linkage, resulting in a more positive return. You will have then have 4 heims instead of 3.
When I converted my car from auto to manual, I used this fork and fabricated the linkage myself with Heims from McMaster-Carr. I’ll try to post some pics and p/ns when I get home.
67 LeMans, 326, M20, 3.31 12 Bolt
