Old 04-14-2024, 06:35 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Default porting went wrong
i have 2 holes where someone went into the water jacket on 1 96 d-port head. its small i think...can i use devcon to fix this? if so which devcon product? i have researched this and my head is spinning.no pun intended. my plan is to patch this so i can run for the summer meanwhile send some virgin 96 d-ports to butler for a port job. what do the experts here think? this was found out after the heads had been cleaned by my local machinist. I just put a new cam and rockers in and was hoping to be at the track and this was found out last friday,
Old 04-14-2024, 06:36 PM
indymanjoe's Avatar
And i cant load pics....
Old 04-14-2024, 06:41 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Grab another 96 head, can’t be that expensive
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
The Following User Says Thank You to J.C.you For This Useful Post:
Old 04-14-2024, 06:43 PM
indymanjoe's Avatar
yea i just found a set but they are going to butler and i dont want to be without my car that long. these had some type of epoxy but it didnt last under the cleaning process. plus i was running these heads for 10yrs with no issues.
Old 04-14-2024, 07:49 PM
Scott Stoneburg's Avatar
If you're looking to use epoxy to fix the holes, Splash Zone marine epoxy holds up very well. I also have a set of D-ports that have Moroso AB epoxy, and has been ran for 10+ years with no problems
The Following 3 Users Say Thank You to Scott Stoneburg For This Useful Post:
Old 04-14-2024, 09:24 PM
indymanjoe's Avatar
both of those came up in my searches as well. Thank you.
Old 04-15-2024, 05:47 AM
Why can't you load pictures, do you need guidance?
I would like to see pictures of where you went through.
1) if you ground thru near the head bolt boss repairs do not hold up for long due to the loading of the cast iron there.
2) depending on where you ground through you may have deminished the stock flow levels if you did such without the guidance of a flow bench.
To grind through even on a head with core shift you have had to grind through some .050" of wall thickness which then means that to have the correct port shape the whole port would have to be majorly reworked!
PM contact me if you need guidance to post pictures.
Old 04-15-2024, 04:50 PM
indymanjoe's Avatar
Pics so I could figure it out lol huge thanks to steve25 for the text message guidance you gave me earlier today! I really appreciated the tips! Thanks again. Butler is 6 months out to port the new heads I got and with your tips on fixing these I should have it on the road in two weeks!
ID:	632110   Click image for larger version
Old 04-15-2024, 07:32 PM
I forgot to mention that if the other 6 intake ports are scalloped out like those 2 then fill them in as well.
When done it should look like your other set of 96 heads.
Old 04-16-2024, 08:02 AM
GTO-relic GTO-relic is offline
epoxy isn't going to hold long into a water jacket.
it needs to be professionally welded.
that has to be at least brazed, gas welded with a torch.
or professionally cast iron welded which is more cost than the heads are worth.
Old 04-16-2024, 08:22 AM
prostreet64's Avatar
prostreet64 prostreet64 is offline
I did the same thing when porting the heads on my 403 Olds. I had a friend who is also a very talented welder braze the hole up with bronze rod iirc. I ran that engine hard at the track for many years and never had a problem.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
The Following User Says Thank You to prostreet64 For This Useful Post:
Old 04-16-2024, 08:25 AM
yeh the NHRA SuperStock class engine builders have been filling exhausts ports with braze for decades. it works.
The Following User Says Thank You to GTO-relic For This Useful Post:
Old 04-16-2024, 10:15 PM
blueghoast's Avatar
I've used JB-Weld on cast iron heads before to with good success.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 04-29-2024, 09:57 PM
joes455 joes455 is offline
It's the antifreeze that eats epoxy
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
The Following User Says Thank You to joes455 For This Useful Post:
Old 04-30-2024, 05:56 AM
He only needs to get thru the summer on the repair work, not for years
Old 04-30-2024, 08:07 AM
That style of intake bowl porting goes against my tinking.
Old 04-30-2024, 10:09 AM
indymanjoe's Avatar
thanks for all the replys.
i found a set of e-heads local of all places (never works like that for me)
picking them up from the machine shop today,couple delays but it is a friend of mine.
naturally I found the e-heads after I bought a set of 96's locally. ��
