New 11-bolt water pump on the block at JEGS
Can't say I've seen this one, yet: https://www.jegs.com/i/JEGS/555/5108...kaAgcwEALw_wcB
Says it's a new product, that impeller looks pretty nice, and I like how they cast a twisted look the housing casting to differentiate it. I just put a brand new Flowkooler 11-bolt on my car, so who wants to give this new thing a shot??
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post: | ||
I don’t get the whole twisted look idea doesn’t seem to add anything Don’t know it has any cooling benefit over the milodon or others
I am happy to see the aftermarket supporting Pontiac’s though. So many other oarts we need more though than duplicates. Like a proper 69 bird license plate bracket.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I recently installed this new Jegs pump.
Aluminum body, composite, (plastic), impeller. Came with two gaskets and a new plate. Has two sets of pulley attach holes, one for Pontiac and the other for Chevy (I guess). No issues installing it. I did the usual plate clearance mod, cools fine
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
The Following User Says Thank You to Singleton For This Useful Post: | ||
And a composite impeller, huh? That's interesting. That's one way to prevent corrosion, and most OEM impellers on modern cars are actually plastic/composite... that's definitely a first for Pontiac water pump options, though.
Didn’t measure it, but it was probably .080-.100 clearance initially
Not all parts are created equal, but after all the years of problems that BMW experienced with using composite impellers in water pumps, I personally would steer clear of any water pump that doesn't use a metal impeller. The composite impellers can crack and sheer off from the shaft, leaving you without coolant flow and an engine that's going to overheat. It was a major debacle for BMW, which is the other automotive universe I'm involved with. This is of course a different design, but composites become brittle with age and heat. Given this is an $84 product presumably manufactured in China, one has to wonder how it will hold up. Time will tell.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 11-22-2021 at 05:57 PM. |
Thread Tools | |
Display Modes | |
