Old 10-29-2021, 04:21 PM
wooftfd wooftfd is offline
Default Rear carrier ID
got this carrier in a box of parts, I think its a BOP 8.2, 3.55... Cant really find any casting numbers, can anyone tell me what year, or if its a safe track, or open?
Name:	carrier 2 (1).jpg
ID:	576490   Click image for larger version
Old 10-29-2021, 04:27 PM
another pic
Old 10-29-2021, 05:31 PM
I'm thinking a 66 safe track? it has 4 pinion gears... and a 3.56 gear set...
Old 10-29-2021, 11:25 PM
What part number & dates are inscribed on the outside edge of the ring gear & the face of the pinion head?
Ring gear bolts are not '64-69 Pontiac 8.2. Have a good feeling it's later, then there would only be two possibilities...
Old 10-30-2021, 12:09 PM
AG's Avatar
AG AG is offline
Look for the date code on the ring gear.
Old 10-30-2021, 12:58 PM
Ring gear 39-11 GM 6690
Pinion says 39-11 GM 69 E A
Looks like a new set of gears, no wear anywhere...
And I'm pretty sure its a BOP 8.2, has a 2" tall deck?
GM 8.2" 2.73:1 and down, 2-series, 1.615" deck height 3.08:1 and up, 3-series, 2.000" deck height
Old 10-30-2021, 02:19 PM
AG's Avatar
AG AG is offline
It's a 1969 4 pinion 8.2" with 7/16" bolts.
Old 10-30-2021, 03:29 PM
so... This will fit in a 1964 rear end, and will take my stock axles?
Sorry if its a dumb question!
Maybe a little more info...
64 421, compression at 9.5, ram manifolds, tripower, mild head work on 716 heads, 3.35 rear ratio, stock 4 speed, stock sized tires, no track time, but will jump on it from time to time...
64 housing and axels ok to use?
Old 10-31-2021, 03:47 PM
AG's Avatar
AG AG is offline
It will fit any 64-72 8.2" Pontiac rear. You should check the condition of the posi before you install.
Old 11-01-2021, 10:35 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Would recommend JD Race, he just did mine 330-990-8155
