Opinions on reproduction in dash tach
My GTO didn't come with a tach ... was thinking about a reproduction in dash tach like offered by our hosts. I will be using a point ignition. I don't need to have a Rally dash PCB do I?
Any opinions on these tachs? |
Don't know what PCB is but I have one of these tachs in my car and it works great. My only complaint is that it's dull at night but that might be unrelated.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Printed circuit board?
Yes, there are two different PCBs for either rally or standard gauges. Was wondering if the reproduction tachs required a rally type PCB or a standard.
Now that I think about it ... I don't think the PCB would extend over to the clock/tach slot anyway. |
AFAIK the two different tachs were for transistor/electronic vs points ignition and date back to 1963 (Delcotronic). For a points ignition a simple passive circuit was enough but for an electronic ignition a transistor front end was added to the same circuit.
I’ve used the aftermarket (PY) tach with both points distributor (w/ Pertronics) and HEI distributor and it works fine. The PCB IIRC is not part of the dash tach or clock. It’s a stand-alone and not part of the Speedo and gauge cluster
1968 LeMans conv. 350 HO - 4 speed triple white (hear it idle here) https://www.youtube.com/watch?v=eVmq...ature=youtu.be 1968 LeMans conv. 350 - 4 speed Solar red/pearl |
The Following User Says Thank You to nytrainer For This Useful Post: | ||
Confirmed, the clock and tach are stand alone units. The printed circuit board is for the speedo and oil/fuel/temp cluster.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
my opinion: they're trash as far as aesthetic quality. functionally it worked. visually, it's horrible. maybe they've gotten better since I bought mine around 09. it had a black ABS case instead of metal so you can't use a factory light harness on it since the housing doesn't ground. at night it was black and you couldn't see crap, the lights did nothing for it. it was so dim I initially thought the lights weren't working. super noticeably different than the instrument cluster's brightness. it didn't fit very well in the pod hole so you could see edges all the way around it after you spent an hour trying to center it. it also had slopped silicone exposed where they glued the face into the housing.
I hated it from the day I had it until I finally just put a hood tach on the car and put a factory clock into the dash. this goes into the category of: better than nothing if you really want it and have nothing else but another flaming beacon of "repop sucks" in my book. other opinions may vary! |
now tell us how you really feel ;-)
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
The one I'm looking at has a metal housing, backlit like the original, and mounts like the original ... I'm guessing it's a different product. Picture of it looks pretty good.
My previous comments were based on a tach that had a metal cup..
I knew you would know this Mr. Peterson. The professor of the Pontiac hood tach!!
ah, someone must have stepped up to offer a better repop. mine came from somewhere between 07-09 vintage. good to know!
if you dont mind NOT being able to read it at night ,,,, buy one
the illumination is super whimpy I just went thru this with a clock in a 68 |
Did have to mod the light circuit to convert a factory hood tach to run with an HEI. Think I used a Vega circuit board (little round white ceramic one with plated on resistors. Changed the one cap to switch from 4 to 8 cyl then wired the hot lead for the transistor to the lights and changed grey dash light lead to hot in run. Calibrated with a pencil and eraser. Worked pretty good.
You can't upgrade the OEM bulb to a brighter LED?
Probably, just a bayonet base. Last time I modded one was before LEDs.
The Following User Says Thank You to padgett For This Useful Post: | ||
I had my hood tach serviced by another party this summer. Excellent work and the bulb were upgraded to LED and are bright/white and easily read, using the original sockets.
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
The Following User Says Thank You to 68gtoMN For This Useful Post: | ||
