Tri-Power Tech 57-66 Tri-Power Talk
Old 02-16-2021, 06:18 PM
Jonsie Jonsie is offline
Default '65 Cat accelerator linkage
Regarding the firewall mounted linkage on a '65 Cat w/auto trans: was the same linkage used for both 4 bbl. applications and tri-power? I believe I have heard mention of differences, but I don't know for sure. Any help greatly appreciated!
Old 02-16-2021, 08:48 PM
stevep's Avatar
stevep stevep is offline
I believe that everything is the same up to the bellcrank.
Old 02-16-2021, 08:50 PM
Difference in the bellcrank?
Old 02-17-2021, 11:39 AM
pfilean's Avatar
pfilean pfilean is offline
Yes tri is different
Old 02-18-2021, 12:05 PM
Yes, I have the Master Catalog also, I can't see any differences on page 416?
Old 02-18-2021, 02:46 PM
pfilean's Avatar
The inset sketch in the middle of the page is for tri-power ST. Looking at the two bell crank sketches about the only difference seems to be the link to the automatic transmission. But why that difference only for tri-power manual transmissions? Would seem that the same should apply for 2 or 4 bbl ST also. Maybe just an oversite or confusion on the part of the draftsman who made the sketch that was never caught on proof reading.
Old 02-19-2021, 12:59 AM
Dick Boneske's Avatar
I have several '65 bellcranks that are freshly plated. They were the same from '65 to '67 for sure. PM me if you need some of these parts.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-19-2021, 11:12 AM
mgarblik mgarblik is offline
It's a little hard to tell from the tiny pic, but the bushings, grommets, and retention method for the bellcrank, tri-power vs 2bbl, 4bbl look to be different. It looks like the bellcrank is supported by rubber grommets and felt washers vs hard plastic bushings and retained by clips on the tri-power. Possibly because of the extra load to pull three carburetors open vs one.
Old 02-19-2021, 11:46 AM
Thanks fellas for your replies. Dick, I will touch base w/you on MON regarding the correct pieces. We're in FLA now, returning home then, regards...........
Old 02-19-2021, 12:04 PM
Here is my collection of parts.
BONESTOCK GOATS
