Old 02-18-2021, 10:51 AM
ponchorob ponchorob is offline
Default 66. 2bb carburetor
can get a stock 389 2bbl carburetor from a 2bbl 389 engine...my big QUESTION is ist the same as 66 tripower center carb....?
Old 03-13-2021, 07:35 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Not sure, but the correct# on the float bowl for a 66 center carb is 7031575
Old 03-14-2021, 06:10 AM
Kenth's Avatar
Kenth Kenth is online now
It is not the same, but can be made work the same.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-14-2021, 08:37 AM
chrisp chrisp is offline
If from a 66 & has divorced choke It will work .
Old 03-14-2021, 10:07 AM
Dick Boneske's Avatar
Yes, if it has a divorced choke, it will work. While you're looking, ty to find one with larger venturi diameter than the 575 "correct" carb.
If you're considering switching to an electric choke, the big car version with the choke mechanism on the throttle body will work fine.
I have several different choices here if you're interested. PM for details.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Thread Tools
Display Modes
