Old 05-22-2021, 01:40 AM
fbd73's Avatar
fbd73 fbd73 is offline
Default Deck Lid Struts
Hi All,
Has anyone fitted deck lid Struts to their vehicle? My '73 has a spoiler and the lid won't stay up. I bought a set of heavy duty torsion bars but haven't fitted them yet as they seem to be a real pain to do it.
I had a thought about fitting struts to the lid and wondered if they would work.
Any thoughts?
George
Old 05-22-2021, 09:45 AM
78w72 78w72 is offline
i think they make some fancy expansive struts for these cars, cant recall the company though. the torsion bars arent that difficult to install, ask some members on here that have done it or check with some body shops in your area, these are replaced quite a bit when cars are restored.
Old 05-22-2021, 10:13 AM
ID67goat's Avatar
ID67goat ID67goat is offline
Would probably take more effort to figure out the geometry for the struts than to just replace the torsion bars...
Old 05-22-2021, 10:54 AM
bird72's Avatar
bird72 bird72 is offline
You only need to replace one of the torsion bars. Spoiler cars had one thicker one. I forget if it is top or bottom one. I have a rod to replace on mine. I just added spoiler and it stays up. but will fall if you bump it while up. I realized I can't change mine unless I peel back vinyl top and it being original and a keeper, I leave as is for now. In your case, change the rod. If car is painted, I would paint rod first, tape protect as needed and touch up any scratches after on.
The Following User Says Thank You to bird72 For This Useful Post:
Old 05-22-2021, 12:29 PM
Formulabruce's Avatar
I have used the single strut set up. Its around 100 dollars and bolts to DS , INSIDE the seal gutter, Under the seal. The angle of the strut is adjusted by spacing the arm bracket under the gutter, in the trunk, down a tiny amount. One thing I like about it is that it lifts fully and stops. I have my deck lid on my power lock remote. I can click to open and its up and my wife doesn't have to touch it, or hold it up the rest of the way.
The trunk does NOT leak. This can be installed without messing up your paint or taking off the filler panel.
That said, when building a car I would put in the 1 stronger bar ( for pass side) .I can get you info on the strut set up if you want.
Old 05-23-2021, 06:26 PM
fbd73's Avatar
Hey, that sounds good Formulabruce. If you can send me the info on the strut set up, I can see which one will work best for me. This car is no where near original so I can do either one.
Old 05-26-2021, 12:17 AM
This place makes them. That said I do Not see them on their current website. See pics below.
https://www.eddiemotorsports.com/Default.asp
NOTE Part Number on my slip, its small. The car pictured is NOT mine, and probably a early second gen Camaro.
NO holes drilled in the "Boot" lid. I bet they would make them for anyone using this part number.
This can keep KEYS, and for my part it keeps my wifes fingers ( rings) off the paint
Name:	eddie trunk order.jpg
ID:	567265   Click image for larger version
ID:	567266   Click image for larger version
ID:	567267   Click image for larger version
Old 05-26-2021, 09:26 AM
Stan65 Stan65 is offline
Found them on their current site, it is with the billet trunk hinges, 70-81 Camaro hinges, scroll to the bottom. $98
The Following User Says Thank You to Stan65 For This Useful Post:
Old 05-26-2021, 09:28 AM
burd's Avatar
burd burd is offline
The Fisher Body book shows how to adjust them, it’s easy, dont butcher your car with that crap,
Old 08-19-2021, 07:52 PM
fbd73's Avatar
Thanks all.
I actually ordered the Camaro strut kit but after talking to my body shop, we are going to try to fit the correct torsion bar (which I already have).
Apparently though, you have to remove the rear screen to be able to remove the panel that covers the torsion bars. My painter remembered this when he was reassembling everything.
Any thoughts?
Old 08-19-2021, 07:58 PM
the rear window doesnt need to be removed to to remove the filler panel & get to the rods. there might be some window sealant in a couple areas but it will come right out.
place a thick blanket around the glass while installing them for some protection.
Old 08-19-2021, 08:19 PM
You DO have to remove the rear window chrome though. The two lower "L" shaped pieces to be able to remove the torsion spring cover.
The "strong arm" pivots and locks in on the DS , but is in fact the pass side torsion bar. See video below
https://m.youtube.com/watch?v=BLzzsyD-hek
Old 08-20-2021, 07:30 AM
cnc's Avatar
cnc cnc is offline
Best tool I made when I did my torsion rod works slick
https://m.youtube.com/watch?v=2i9hfKe8HLA
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
The Following 2 Users Say Thank You to cnc For This Useful Post:
Old 08-20-2021, 12:10 PM
jhein's Avatar
jhein jhein is offline
Slick indeed
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 08-20-2021, 12:12 PM
sorry i assumed removing the window trim was a given to get to the panel. main point was the glass doesnt need to come out.
Old 08-20-2021, 12:54 PM
You are right! Just mentioning it so he doesn't get charged for a glass removal.
The "strong arm " tool is pretty slick.
Practice always helps too
Old 08-21-2021, 12:09 AM
Aus78Formula Aus78Formula is offline
If the glass has to come out for something else, perfect time to attempt the fix, just in case.
Old 08-21-2021, 02:48 PM
One of my cars has the one "strong arm " rod and the strut, which basically takes over at about 6 inches where the rod can't lift anymore
Old 08-21-2021, 04:55 PM
bird72's Avatar
You guys use your trunks? Wheeee......
72 Bird
Old 08-21-2021, 06:18 PM
2 large collapsible Cabellla directors chairs take up a lot of space!
Thread Tools
Display Modes
