Tri-Power Tech 57-66 Tri-Power Talk
Old 05-26-2021, 07:27 PM
gtorich gtorich is offline
Default yellow throttle spring
Never ever thought about it...........was getting an alignment today and the guy mentioned you dont have a problem with just that one yellow spring, what happens when that breaks.....................anyone else running a smaller spring inbetween the yellow one.
Just curious if anyone is using two springs.............i have never seen two springs in a pontiac tri power so far.
Rich
Old 05-26-2021, 07:38 PM
Brewster's Avatar
Brewster Brewster is offline
I have seen the double yellow but only on a four barrel. Ive also single yellow and blue springs on quad jets. They never break unless played with allot taking them on and off. The double wasnt for redundancy it was for higher tension.
Daubert20's Avatar
Daubert20 Daubert20 is offline
I run two springs. You need two to pass tech at our closest dragstrip, Island Dragway.
www.gtopa.org
GTO Association of Pennsylvania
Webmaster
Old 05-26-2021, 08:18 PM
if possible a pic would be great.
Rich
Old 05-26-2021, 09:32 PM
burd's Avatar
burd burd is offline
Thought all 4 bbls had a blue and a yellow
Old 05-26-2021, 10:12 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Factory Springs
Throttle return springs for 64-67 GTO.
64-65 4BBL. and Tri-Power (single yellow).
66-67 4BBL. and Tri-Power (single blue).
Old 05-26-2021, 11:31 PM
turbo69bird's Avatar
What happens you key the car to off! I know just happened to me last week on my 61 MGA when the cable got stuck. I wedged it part of the way open and drive it home too. Thank god it was a stick car made it fairly easy
960 HP @ 11 psi, 9.70 at 146.
Old 05-27-2021, 07:06 AM
Daubert20's Avatar
Picture attached of my two springs.
Name:	Two Throttle Springs.jpg
www.gtopa.org
Webmaster
Old 05-27-2021, 11:35 AM
wbnapier wbnapier is offline
I had no idea there was a risk that the return spring would break. I did have an issue with the a nut falling off the linkage once and causing a problem. I use nylocks on them now.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 05-27-2021, 02:54 PM
burd's Avatar
Nut holding the steering wheel can be an issue too
Old 05-27-2021, 04:25 PM
indymanjoe's Avatar
Track tech made me put 2 on as well.never thought about it prior to that. Qjet 4bbl in my case. makes the fun pedal a little stiffer.
Old 05-28-2021, 04:06 PM
Jeff Hamlin's Avatar
I've always run two springs regardless of colors and correctness.
Even on my Cammers.
ID:	567437   Click image for larger version
Old 06-08-2021, 04:08 AM
lust4speed's Avatar
All three of my Fremont production GTO's came with a dual wrap yellow spring and I collected another half dozen or so springs in the local pick-a-parts back when we could find the early cars. Tension with both springs is very light and the double springs pass the tech inspections - well at least after I have the tech look a little closer. I hate the single spring that came on the 65's, and added a set on my '65 Tri-Power.
Name:	Throttle springs.jpg
Mick Batson
Old 06-14-2021, 04:00 PM
Dick Boneske's Avatar
I've never seen a throttle spring break on a Tri-Power. Too much spring tension makes these setups virtually impossible to drive without the herky-jerky throttle problem. Rochester 2G carbs all have a spring under the accelerator pump that pushes the throttle plates closed--not as much pressure as the return spring, but it's significant.
The only reason I can think of to run dual springs is to satisfy a tech inspector.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-14-2021, 09:37 PM
Rich-Tripower's Avatar
Last Summer I added a second spring because well some forms of logic seem to dictate that it is a good idea. And I've been experiencing that exact herky=jerky problem you mention. The throttle sticks right off idle and when you press harder to overcome the resistance you get more throttle than you want. I'm taking the second spring off with the hopes the smooth throttle function will return.
Old 06-15-2021, 12:54 PM
That's exactly what I was referring to. The car is miserable to drive if there is too much throttle pressure. Sometimes, there is a problem with the throttle sticking just off idle (about 12-1500 rpm) This is very annoying, also. A stiffer return spring IS NOT the solution. Instead, fix the reason for the throttle sticking. I've found it usually happens only when the engine is hot. The only way I've found to fix it is to disassemble the center carb base and provide a minimum of .003" clearance between the brass shaft and the cast iron base. This is true whether the bas has had bushings installed or not. Evidently, as heat increases, the clearance decreases and causes sticking.
If anyone else has ideas on this issue, please chime in.
BONESTOCK GOATS
Old 06-15-2021, 09:37 PM
My center carb has a basically brand new reproduction base.
Old 06-16-2021, 06:40 PM
Hey Dick..........im just gonna run the one spring...........with the adjustments you made when i was over by you.............car is running great.
Rich
Old 06-17-2021, 10:32 AM
60sstuff's Avatar
This “2 springs” talk is kinda hilarious, when speaking of 64-67 Tempest Series automobiles.
First, the Pontiac engineers that designed these new cars didn’t see the need for 2 springs.
Second, if there was a problem with the springs breaking and possibly causing collisions, GM would be held responsible and sued.
Third, over decades of use, these single springs if installed as the factory intended will last forever ….. providing someone hasn’t done some other silly modification from factory stock.
Now, if someone were to stretch or damage a spring from the factory setting, than all bets are off.
Old 06-17-2021, 11:42 AM
grandam1979 grandam1979 is offline
There is a reason they went to two spring they got smarter same reason they did away with the tri power it was out dated just like almost everything becomes sooner or later. FYI new does not mean always better my $6000 zero turn broke a new spring in less than a hour after having it delivered
