Tri-Power Tech 57-66 Tri-Power Talk
Old 08-07-2021, 01:03 PM
mike w mike w is offline
Default TRIPOWER CARBS FOR SALE
I have several sets of tripower carbs, which I usually do not sell, as I prefer to mount them on an intake to sell as complete unit. However, I am low on manifolds, so will sell off a couple sets of carbs. These carbs are in process of restoration, could get most out in 10-14 days.
Each set will be set up to match your motor...opening up idle circuits, adjusting power valve/piston, and jetted correctly.
These carbs will be fully restored, not rebuild, and guaranteed. I can sell them in correct factory Chromate color, or in natural finish, without color.
Prices range form 1250. a set (66 set, clone center, correct ends with minor rash on airhorns...again, guaranteed.. to..1750 for correct set of 66 carbs, correct center and ends, show quality.
Have 61 to 65 sets available, as well.
feel free to call with any questions. Quantiies limited.
I cant seem to add pictures. Please email or text me if you want pics.
309.360.6385
Old 08-09-2021, 09:08 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
What is the price for correct 65 set, correct center ,and correct part numbers. natural finish if still look nice
Old 08-09-2021, 12:17 PM
65gto69's Avatar
65gto69 65gto69 is offline
May be in touch for a set for 65
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 08-09-2021, 12:27 PM
Call anytime. I am in Illinois. 309.360.6385
