Old 08-25-2021, 08:40 PM
lucky1 lucky1 is offline
Default 66 tri power manifold.
Is that thumb shaped raised area behind the thermostat housing on a
66 Tri power intake manifold solid cast iron ?
Thinking about tapping it and using it as a mounting point.
Thanks.
Old 08-25-2021, 10:13 PM
JSuchma JSuchma is offline
Thanks.
I just checked one of my 66 tri power factory intakes from the inside coolant passage and there is no indention, so I would say drill away! For grins..... I also looked at the aftermarket aluminum tri power intake I have and it is solid also.
Old 09-01-2021, 03:25 PM
Dick Boneske's Avatar
The '65 has that raised boss, also. There must have been an idea for use for A/C brace or other option never used.
Here are both '65 and '66 setups showing the boss.
Name:	Mike Keafer Tripower 002.jpg
ID:	572283   Click image for larger version
Name:	Adrian '65 Tripower 025.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Thread Tools
Display Modes
