Old 10-05-2021, 07:35 PM
Mark66 Mark66 is offline
Default Big 66 shifter ID
I have a factory Muncie 4 speed out of a 1966 Grand Prix and I am 99% certain that the shifter unit is original to the transmission. Hurst is embossed on the shifter handle. How can I determine if this is an original factory shifter unit (made by Muncie I assume) or a Hurst shifter unit. The unit does not have the bolt stops. one usually finds on the Hurst shifter units.
If it is a Muncie shifter unit would I be wise to swap it for a Hurst unit - and if so, which Hurst unit would be a direct replacement? Thanks
Old 10-06-2021, 07:25 PM
stevep's Avatar
stevep stevep is offline
Does it have 3139 stamped on the base of the handle?
Old 10-08-2021, 11:27 AM
I will check on that this weekend. Do not recall seeing a number of the handle base but I wasn't looking for it at the time. Will probably send the shifter to Pete Serio for cleaning and repair before putting it in the car.
Old 10-10-2021, 06:38 PM
Stevep
The chrome handle does indeed have 3139 stamped on the base. What does this signify?
Mark66
Old 10-11-2021, 07:41 PM
stevep's Avatar
It means that it is a correct 1965-1966 Pontiac B body shifter
