Old 10-07-2021, 12:42 PM
kalvert's Avatar
kalvert kalvert is offline
Default Selector return spring
anybody have a part number for the gear shift selector return spring for a 65 column shift? im tired of mine flopping around, my local steering column guy couldnt go back that far in his catalog to find the correct spring.
Old 10-08-2021, 11:02 AM
pfilean's Avatar
pfilean pfilean is offline
Not sure which spring you are referring to. And there may be a difference from tilt to non tilt columns.
Group 4.008 lists a small coil spring at the shift lever (exc tilt) 9779355. In picture it looks like a spring to return the lever to normal position after yo pull it tword the steering wheel to remove from park.
Group 4.010 lists a part 391537. Says five coil located at at shift lever bowl for tilt wheel. But picture looks like a rebent paper clip. I don't know which is correct for you situation.
Old 10-08-2021, 12:16 PM
kalvert's Avatar
tilt column, clip or spring to return the lever to normal position. thanks for the info!
