Old 10-09-2021, 08:43 AM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default axle removal
Hi guys,I have a 69 GTO rear end and my problem is: how do I remove the rear axles.The pin inside the differencial does not have a bolt to hold it in.I don't want to start beating on the pin until I know that I won't ruin it.I looked online and I could not find a differencial without a pin bolt.Thank you for any help.
Tim
Old 10-09-2021, 09:58 AM
72pontiac's Avatar
72pontiac 72pontiac is offline
are those not bolt in axles, at the brake backing plate
Old 10-09-2021, 10:36 AM
yes they are,thank you very much.So I just pull the axles out?
Old 10-09-2021, 11:02 AM
72pontiac's Avatar
Yes remove the 4 bolts. It'll pull out. Bearing may be a little snug in the end of axle tube. its pressed on the axle shaft.
Old 10-09-2021, 11:31 AM
Default axle
Thank you very much 72,have a great day.
Tim
Old 11-03-2021, 12:12 AM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
I remember doing this with my 69 Judge back in the 70's. The bearings were so shot, when I pulled the axle, the ball bearings fell out. I was still able to save the axle however.
Old 11-03-2021, 03:06 AM
dataway's Avatar
dataway dataway is offline
I had a heck of a time getting the axle out of mine. Axle doesn't want to come out of the bearing, and bearing doesn't want to come out of housing.
Forget the trick I finally used ... but I read about it on this forum and it worked. Axle came out with the bearing attached of course, as you would expect.
I was hammering on the back side of the axle flange ... and it wasn't working.
Old 11-03-2021, 03:52 AM
I had one stuck and used a slide hammer through one of the axle flange holes.
Old 11-03-2021, 06:36 AM
dataway's Avatar
That may have been what I ended up doing, and I know on the second axle I put a big metal rod through the empty tube and tapped on the inside of the axle.
Maybe I heated it up ... jeez, wish I could remember cause I read something here, went down and tried it and it came right out .. seems like a slide hammer is too simple a solution
Wish the forum had a decent search function with the normal logic searches ... like "and" "not" quotes for phrases etc. Would make it hugely easier to find things.
Old 11-03-2021, 05:09 PM
Default axle
Thanks so much,I remembered about the reversed drum as a slide hammer after I seen it on line.I used my slide hammer it worked fine.
Tim
Thread Tools
Display Modes
