Old 10-11-2021, 04:17 AM
dataway's Avatar
dataway dataway is offline
Default Radio fader, rear speaker wiring
Can anyone draw me a schematic of the circuit for the AM radio fader switch and rear speaker? I've got all the "drawings" from the manuals but I can't find any actual circuit diagram. The AM radio/harness I have came from a single speaker car, so the plug it uses doesn't have a contact for the third prong in the radio that appears to be used on two speaker systems.
Anyway, rather than buy $100 worth of wiring harnesses I figured if I had an actual schematic I could just wire it up myself.
Initially I figured it was just a "speaker out" wire to the fader and the fader split the output between the front and rear, but there appears to be something else going on there.
Thanks.
Old 10-11-2021, 10:44 AM
OG68 OG68 is offline
Do you have a two lead front speaker (+ and -) or just the single green positive?
2007 Cadillac SRX
Old 10-11-2021, 12:26 PM
dataway's Avatar
The harness is a single green lead to speaker. The speaker is a two terminal 10 ohm replacement speaker with + and - which I was planning on running to a local ground. Rear speaker will be another modern replacement speaker with two terminals. By "Harness" I mean the plug that goes into the radio has the yellow power lead in one slot, and a green speaker lead out of another.
Old 10-11-2021, 02:48 PM
I'm too lazy to draw a diagram and five pictures say a lot.
THIS IS FOR THE AM RADIO ONLY
Speaker wire with yellow power wire attached
Connected to switch harness
Theres a small opening above the radio receptacle for the harness clip.
Complete Harness. Note the blue rear speaker wire plugged into the switch harness
ID:	574906   Click image for larger version
ID:	574907   Click image for larger version
ID:	574908   Click image for larger version
ID:	574909   Click image for larger version
2007 Cadillac SRX
Old 10-11-2021, 04:09 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Is that an actual fader or an on/off type switch? My 68 originally came with an AM/FM with the rear speaker reverb switch.
A complete wiring harness, switch and clapped out speaker came on on ebay about 5 years ago for $200 & I hesitated.
I wish I would have bought that when I had the chance. Now I just have the AM/FM with the single dash speaker. So its half correct anyway
I never realized there realized there was another mono option for a rear speaker. thats pretty cool.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 10-11-2021, 04:36 PM
dataway's Avatar
OG, thanks a ton for crawling under there and taking those pics. That's exactly what I needed to see. Makes more sense now.
And, PM sent for the offer, thanks much again.
Old 10-11-2021, 04:39 PM
Its a true fader.
There are actually two different versions of this switch.
Apparently there are front speakers with a pos and ground lead to the plug and speakers with a single pos lead and grounded to the speaker housing. The two switches are wired differently for each type of speaker.
2007 Cadillac SRX
Old 10-28-2021, 04:32 PM
dataway's Avatar
When you guys are installed adhesive sound deadening or insulation on the floor are you running your wires below the insulation or above? I'm kind of hesitant to put it beneath butyl rubber stuff like Noico. Should I put the wires above everything except the carpet?
I'd hate to every have to pull up that big flat cable to the back if it was stuck down with Noico.
Old 10-28-2021, 04:48 PM
factory ran it directly on the floor before the tar paper was installed but you can run it easier just under the carpet if you keep it away from foot traffic. Best route is along the far right side of the floor in the nook where the floor turns up to the rocker panel (just below the belt retractor. Tape it in place so it doesn't end up against the seat leg brackets.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 10-28-2021, 04:52 PM
Stay away from 4 ohm speakers (almost every speaker built since the 70's is 4 ohm) as they will fry your radio over time. The radio is designed for 10 ohms, but you can get away with 8 ohms but no less.
1969 Bonnie Cvt
Old 10-28-2021, 05:25 PM
dataway's Avatar
I got a couple of the modern reproductions that are 10 ohm. Tested on the bench, so far so good.
Old 10-28-2021, 05:35 PM
The fader option migrated in those years… up to 68 it resided on the top of the dash, in 69 it slipped over the tuning shaft on the radio and in 71 or so it moved into the radio.
The reverb and even the 8 track all used the “intercept” concept of wiring in that they insert themselves between the power source and radio itself.
1969 Bonnie Cvt
Old 10-28-2021, 06:36 PM
68ragtop's Avatar
Mine is all under, but I used the factory style floor insulation, so not really a fair answer to your question. I re-coned an original speaker. I forget where I bought the parts, but I might have the info somewhere. Was pretty easy & kind of fun to do actually.
89 Trans am GTA
The Following User Says Thank You to 68ragtop For This Useful Post:
Old 10-28-2021, 06:52 PM
dataway's Avatar
Maybe I will cover the top of the flat cable with wax paper or something, then if I need to get to it at some point I can slice along side it and peel the Noico away easily.
Old 10-29-2021, 11:37 AM
68pongto's Avatar
68pongto 68pongto is offline
I sent you a PM
