Old 10-14-2021, 05:14 PM
thepontiacman's Avatar
Default 1963 PONTIAC Catalina/Full Size Pontiac Manual Trans Set up
Parts are from a 1963 Catalina that is a 3 speed on the column.
Changeover: Pedals with bracket, z-bar with parts and linkage, bellhousing, flywheel, clutch, pressure plate,( flywheel and bellhousing still on engine, will remove) $1700.
Also have 3 speed manual transmission with rods and manual trans shift on the column. $email
driveshaft and rearend will be available also as soon as i can get to them.
Will make package deal if someone is interested in changeover with 3 speed, driveshaft and column.
There may be other usable parts from this car. Let me know if looking for something.
I can email or text pictures.
thepontiacman@yahoo.com
ID:	575181   Click image for larger version
ID:	575182   Click image for larger version
ID:	575183   Click image for larger version
ID:	575184   Click image for larger version
Old 11-22-2021, 06:24 PM
For Sale
Old 01-06-2022, 10:43 AM
Available
Sent from my Moto Z3 Play using Tapatalk
Old 01-11-2022, 04:09 PM
421mike 421mike is offline
Send a message via Yahoo to 421mike
Which 3 speed transmission? Is it the small trans or the h/d T-85? thanks, Mike
Old 01-12-2022, 09:20 AM
Will have to check.
You can pm me or email and I will check.
Old 01-14-2022, 04:29 PM
PM sent.
Old 01-15-2022, 05:31 PM
Dash block off for indicator goes with set up.
