Old 10-27-2021, 11:52 AM
Jimbobeast Jimbobeast is offline
Default radiator core support mounting bushing sequence
What is the correct sequence for the radiator core support rubber mounting bushings? Is it:
Cage nut
big washer
top rubber bushing
bottom of frame channel
bottom rubber bushing
bottom of core support
big washer
bolt
OR do the two rubber bushings sandwich the bottom of the core support and the cage nut sit directly on the bottom of the frame channel? I pick door #2.
ID:	576321   Click image for larger version
Old 10-27-2021, 02:16 PM
DavesGTO's Avatar
DavesGTO DavesGTO is online now
Old 10-27-2021, 04:25 PM
Perfect, Dave. Thank you.
Where did you find that? I looked through the workshop manual, the Fisher Body Service Manual and the assembly manual (obviously not carefully enough).
Old 10-27-2021, 05:21 PM
DavesGTO's Avatar
That was in the assembly manual, can be a bear to find stuff in that thing.
Old 10-27-2021, 06:19 PM
rustedgoat rustedgoat is offline
I just had to save that for later. Thanks
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Of course, the Assembly manual. I should have looked closer. Darn.
