Trunk weatherstrip
I purchased a trunk weatherstrip from Soffseal and having a hell of a time closing the trunk. The weatherstrip seems very thick and over engineered for what it is. Anyone else had a problem with Soffseal?
Hello Joe. I'm sure someone using Soffseal will chime in, But if you can, show us a profile of the seal you used. Some brands are definitely larger than original.
Seems now that I search a little, there is a GM/Soffseal and a Soffseal. A lot more likes for the GM. "Bill"! You might get lucky and find the GM 4484836 NOS seal. They are still out there!!! |
weatherstrip
The weatherstrip 1 3/8 " high
I had the same problem when I finished my '64 in 2017. Leaving the trunk latched helps compress the weatherstrip, which made mine usable.
I was told Soffseal was the best and closest to the original but ???
I used Soff Seal weather strips on my doors and they were very hard to close at first. They got better over time and I am now pleased with them.
James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed |
Had soff seal for my trunk, took it off and got a Metro. Same thing, you could not close trunk lid without Slamming it. Metro was much better.
64 Lemans hardtop 4spd, buckets |
Hi Joe. Look at the profile of this w/s on Ebay. auction # 323081727777
"Bill"! |
What on ran into on my '66
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Bill, Profile of the Soffseal appears to be very close to oem but the oem has 1 void and the Soffseal has 2 voids which you would think would make the trunk easier to close. I ordered a weatherstrip from The Parts Place which will be here today. Not sure what brand it is.
in my 35 years of restos, I'll say softseal is anything BUT soft. way too stiff. I stopped using anything from them once Metro came around. trunk seals were so bad I had to loosen the latch to the point of hearing it rattle on bumps to get it to close without jumping on it kind of thing. Metro seals are definitely softer and would be the go to manufacturer for me.
weatherstrip
Received the weatherstrip from The Parts Place a few days ago. There was no name on the bag but it fit perfect. I was able to close the trunk with very little resistance. One day later it was closing even better. The first weatherstrip I purchased was from Metro. I originally thought it was from Soffseal but turns out it was from Metro. I know there has been good reviews with Metro but I give it a thumbs down. The weatherstrip from The Parts Place has more of a oem appearance and I can close the trunk.
weatherstrip
The one on the left is The Parts Place and the right is Metro. Huge difference
The o.e. weather seals were Skinned also . the reproduction is not
When doing my car I would buy all the major brands a return the ones not used . I do remember the trunk seal . there was a problem with one being to large |
did, Do you remember which one you decided to use?
Thread Tools | |
Display Modes | |
