Door Panel Pull Handle Insert
I am restoring a 1972 Trans Am with a Standard interior and have a question on how the Pull Handle insert, affixes to the door panel itself. I am restoring that car as "correct" as I can, so I am sweating these small/stupid details!
I am assuming I use two collared interior screws (like those shown in pictures 5 & 6). Is that correct? The reason I am confused is because there is nothing other than the two holes in the lower door panel cup (plastic) that would hold the pull handle insert (ie no metal or holes on the inside portion of the door). Picture 1 - Shows the lower portion of the door panel (arrow points toward the cup that the pull handle insert fits into). Picture 3 - Shows the pull handle insert sitting alongside the cup that it fits into. Picture 4 - Shows the pull handle insert sitting inside the cup that it fits into. Picture 5 - Shows the detail of the collared interior screw and the pull handle insert. Picture 6 - Shows the collared interior screw placed into the pull handle insert. Thanks in advance for any help or pictures that you can provide |
OK, some advice if I may. I'm sure you know this part of the panel gets a lot of "strain" not having a deluxe pull handle.
EDIT here: You are missing a part that bolts to your door. One of two shelves. I have taken the metal "shelf" and welded a machine screw nut to the bottom of it and used a machine screw with same top as originals. OR make sure you have a nice tight sheet metal clips on the shelf, and your door hinge Detent roller is well lubed and spins nicely. Your screws look correct. the sheet metal clips will slide to right location. Originally there was no clips, they fitted the screws into the slots you see, and they pull out easily, or wreck the door panel. Here is a pic of what you need, and what I was talking about above. This pic is a '72 T/A a member restored.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 11-05-2021 at 12:50 AM. |
the "shelf" part that bolts to the door is definitely needed to attach the panel right, without it there is nothing to support the panel or for the screws to attach to. if needed i have some of the shelf brackets id sell for cheap...
a nut or clip is a good idea for the shelf bracket but if the slots arent wallowed too bad you can flip them over with support underneath & carefully hammer the back side to close the slot back up & provide a good grab for the screws. doing that worked good on my 72 firebird but i have the deluxe pull strap i use to pull the door closed so not much stress is put on them. |
Formulabruce - Thank you for the reply and excellent advice. I, too, was very concerned with the amount of "pull" on the door and nothing substantive to hold the door panel to the actual door frame.
78w72 - I would definitely like to purchase the "Shelf brackets" that you have. Let me know how much and how you prefer payment. Shipping zip code is: 33549. Thank you both for the replies! |
neat - I have never seen those plastic(?) inserts before - and I've pulled parts off of (for someone in my age range) what I believe to be ALOT of 1972-1977 f-bodies.
to add some strength to the only door "pull" the door has. Will look at a base interior today
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
Formulabruce - From the research I conducted, the inserts are not present on the Deluxe interior door panel. As you elude, the Deluxe interior door panel has a door strap that mounts to the door, giving it some strength; unlike the Standard interior door panel which doesn't use the strap.
Sadly, I couldn't find this view/breakdown in any assembly or parts manuals that I have. The greatness of this forum, is the knowledge that you guys have and are willing to share. |
I couldn't agree more.
my 72 firebird does not have those cups & is the deluxe interior with pull straps. the screws just go right into the panel. ive parted a lot of these cars as well & have never seen those cups. i did locate those brackets for you, will send a PM later tonight with details. |
PM sent |
78w72 - I replied to your PM. Thank you for locating the brackets.
I'm not familiar with the early years in detail but even looking at first post it looked to me like an addition added by GM later to correct the flimsy area when pulling. Even if it wasn't, that's how it would appear, but also one that can be added or removed just as easily. Good pics too.
I too, could Not find a parts listing in a vintage parts manual.
I would like to know if there is a number on the back of the part. For Pontiac to make this "after the fact" they would be obligated to make it in many colors I would 'Assume" I did find one that disintegrated ( "perished" for those in the UK) and was almost white looking on a 71 Sandalwood std door panel. I will have to assume it was Sandalwood and not black, but the car was a California car and pretty sun cooked. I have a 72 black std car here and it does Not have them. It is a Connecticut car. There were aftermarket company's making and marketing interior related parts in the 70's and even into the 80's for these cars like console lids, covers, cup holders, CB related parts, pedal covers, seat covers, etc. I suppose its possible someone copied the grain and painted these. They had no trouble making hard plastic console lids. "Cal-Custom" comes to mind. Probably made in Japan. ALL of this ..... IMHO
