Old 11-06-2021, 01:13 PM
webfoot's Avatar
webfoot webfoot is offline
Default 1962 Cat wiring help
Unfortunately I misplaced my handy laminated wiring diagram..
The upper left hand side of my fuse panel has absolutely no power, it looks like a small solid green wire supplies 12v to the buss bar. Where should this wire get power from?
The dash harness is completely new so it’s puzzling why something isn’t working.
Also, as I understand it there are no switched ignition 12v power options without tapping into the ignition switch? Just trying to power some auxiliary gauges.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 11-06-2021, 04:29 PM
Stuart's Avatar
Stuart Stuart is offline
There are wiring diagrams online at the Old Car Manual Project website: http://www.oldcarmanualproject.com/t...ing/index.html
Old 11-06-2021, 04:46 PM
webfoot's Avatar
That’s real helpful, thanks. Looks like it gets power from the backup light/neutral safety switch. I have a manual transmission with floor shift column, is there a different harness or adapter needed for this?
-Jeremy
Old 11-06-2021, 05:48 PM
webfoot's Avatar
Actually that is a light green wire, looks like that part of the fuse block gets it’s power from the headlight switch, dark green.
-Jeremy
Old 11-11-2021, 02:05 PM
webfoot's Avatar
Easy fix, the switch harness was not fully seated.
-Jeremy
