Old 11-16-2021, 08:25 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Looking at buying new leaf springs
As I'm working on the exhaust and making sure the tailpipes clear everything with the rear end hanging down and when its sitting at ride height. Looks like the drivers side spring sags more than the passenger side. I have always noticed the car has a lean to one side. But just accepted it. So now, im looking at replacing the leaf springs. There isnt a huge price difference from a stock replacement mono spring to the Calvert Split Monos. So I have 2 questions...
1.. Anyone running the split monos on a car that sees regular street miles, and is there any issues ?
2.. Do I buy the "stock height" or 1" lowering? I like the ride height of my car now and have read that when people replace the springs the ride height is higher due to the new leafs.
Here are a couple pics for reference of how my car sits at rest. Notice the driver side tire is in the wheel well a little more.
ID:	577968   Click image for larger version
Old 11-16-2021, 08:54 PM
AG's Avatar
AG AG is offline
I went from stock mult-ileaf to stock height Calvert split-mono springs on my '68 and there was no height change.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-16-2021, 09:52 PM
AG , do you have any pics of your car from the side?
Old 11-17-2021, 08:49 AM
chuckies76ta's Avatar
Scott: I just install Calvert split mono leaf springs on my wife's 68 Firebird. I bought the first set part # 230-45 and found they were a little high. So I purchased the second set part # 230-44. I really didn't see much of a difference from the first set to the second set. Maybe dropped 1/2". I have a friend with a 67 Camaro who has the part # 230-43 and he says it's too low for his liking. I still think the car is too high in the back. There still is these plates you can play around with to setup the springs. https://calvertracing.com/product/sp-1-spacer-plate/ https://calvertracing.com/product/sp-3-spacer-plates/ This is on a Moser 12 bolt. 28" tire.
I don't think there would be any issues on the street with these springs. We also run a dual adjustment QA1 shocks.
Old 11-17-2021, 11:24 AM
turbo69bird's Avatar
How are the split leafs on the street? Calvert told me I can’t run them on the street .
960 HP @ 11 psi, 9.70 at 146.
Old 11-17-2021, 11:36 AM
ta man ta man is offline
Maybe a touch stiffer at the same ride height..not sure why they said you can't run them on the street?
Old 11-17-2021, 01:52 PM
AG's Avatar
AG AG is offline
Here it is.
Old 11-17-2021, 02:36 PM
Thanks for the pics guys, I ordered the "stock height" springs. I guess if it sits too high I can always buy the Calvert Spacers and put them betwee the rear end and the spring. I do plan on some street driving, its not a daily driver, so I hope there are no issues. Did you guys notice a performance difference when switching? More consistent or easier to hook the car? I looked again at the pics i posted and noticed both my pics are the same side..lol..here is the drivers side. For reference
Old 11-17-2021, 06:42 PM
Send Calvert an email. ask about street use. I can't see any issues. Spring is a spring. Need proper shocks to control them. My thinking. Maybe that's there issue. Car looks awesome.
Old 11-17-2021, 08:14 PM
ponjohn's Avatar
ponjohn ponjohn is offline
There HAS to be 1000's of cars running them on the street. I've never heard of complaints.
Maybe they just have to say that.
Old 11-17-2021, 09:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My friend Charlie has them on his mainly street Charger. OD auto trans 500" 383 Hilborn stack EFI so far has not cracked in the 10s but has the mph to. Has A/C on it too! He uses a rear slide vs shackles-before Frieburger did it to the Mayhem Charger.
Picture is out in front of my shop and from the Calvert Racing catalog gallery.
My 79 Camaro/IA has them and I have driven it on the street with them 1" drop and sits just right not too stiff
Skip Fix
Old 11-18-2021, 04:19 PM
blueghoast's Avatar
I know the street racer guy's don't like them for that.
I run old cheap slapper bar that clamp on with u-bolts
I shim them for ride hieght where they mount front and rear
and for tracktsion, Get that snubber against the spring and
If you have the power your 60-foots will drop.
Mine 60's in the low 1:40's and high 1:30's.
Check out some leaf spring suspension site's.
GT
Old 11-18-2021, 08:52 PM
Did any of you guys opt for the spring sliders?
Old 11-18-2021, 10:32 PM
Not me. I did look at them and decided the mounting and whatever needs to be done wasn't worth it. I took a good look at the shackles at the back and I figured it allowed the spring to move back and forth pretty much the same.
Old 11-18-2021, 10:39 PM
The tech at Calvert didnt make any mention about them. But a friend asked me if I bought them to go along with the springs. I figure if it wont hook i can always add later.
Old 11-18-2021, 10:44 PM
Ya, A friend of mine ran his Camaro into the 9's this summer with Mono leaf and Caltracs, no sliders. He was fine with the shackles.
Old 11-19-2021, 07:14 AM
charlie66's Avatar
I put the sliders on my car.
My Half AN Injun.....
Old 11-19-2021, 10:42 AM
78w72 78w72 is offline
i recall hearing the "no street" thing for mono leafs was due to safety concerns... in an accident or other extreme situation they can break & let the rear end go free or sideways compared to multi leaf steel springs.
i was considering mono leafs for a car many years ago & thats what i was told by a few mechanics & racers regarding mono leafs on the street. but i know tons of guys use them on the street without any issues so could be one of those things where a company just makes the statement to cover their butts for IF it might happen.
Old 11-20-2021, 10:30 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I put the stock height ones on mine a few years ago. Very happy with the street and track performance. A good double adjustable shock is a great thing to have to go along with the Caltrac springs and bars. Car is 3300 lbs race weight, 275/60R15 tire on an 8" wheel.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 11-20-2021, 10:58 PM
I'm going to buy the adjustable shocks from CalVert racing. After i get the new springs installed I will measure for static length of the shocks. They are not in the stock position so I want to make sure I get the right length shock. The leaf work gs are supposed to be here Monday.
I need to put myself and the car on a diet. Im at 3550 race weight, maybe 3600 now with the IA block.
