Old 11-22-2021, 11:54 PM
cdnturboz's Avatar
cdnturboz cdnturboz is offline
Default 1972 Trans Crossmember Differences
I have a 72 GTO that originally had a 400 with turbo 400 trans. When I got the car it was missing the crossmember. I’m in the process of converting the car to an m22, but need to find a crossmember.
My question is what year(s) cross members will work? Does it have to be a 4spd crossmember or will a turbo 400 one work? Will any other BOP or Chevelle crossmembers work?
1972 Pontiac Le Mans GTO
Old 11-23-2021, 02:24 PM
rockys1970 rockys1970 is offline
Any 68-72 Pontiac A-Body cross members should work, EXCEPT convertibles which have a different length. The frame ends have rubber insulators and metal caps that bolt to the frame.
I believe Chevy units have tubular construction compared to the flat style Pontiac used. I think that Olds & Buicks used units similat to Pontiac.
Old 11-24-2021, 02:41 PM
cdnturboz's Avatar
Thanks - I’m guessing no difference 6cyl vs 350, etc
Old 11-24-2021, 05:06 PM
One thing I’ve found helpful is to check the catalog of a major reproduction parts supplier to identify what different year parts will interchange.
I remember checking the AMES catalog and saw that they sell the same crossmember for ‘64 - 72 hardtop cars and two different ones for ‘64 -‘67 and ‘68 -‘72 convertibles.
No different ones depending on what transmission was used, all the same.
Old 11-24-2021, 07:19 PM
OG68 OG68 is offline
Ames I would trust in that regard. Not the others.
2007 Cadillac SRX
