Old 11-23-2021, 06:17 PM
Transamric's Avatar
Default Where did it go!?? SD distributor hole spacer.
Been searching for the company that makes (made?) a distributor hole spacer so I can use a standard diameter dist. in my SD block. Can't find one anywhere. Am I making this all up?
Old 11-23-2021, 06:23 PM
jhein's Avatar
jhein jhein is offline
This?
https://butlerperformance.com/i-3164...butor%2Bsleeve
Nice looking pair of TAs there too, BTW.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 11-23-2021, 06:55 PM
Transamric's Avatar
This?
That's the one! I was using the search term "spacer" instead of "sleeve". I see The Parts Place has a sleeve also.
Thanks on the TA's. '70 is a RAIII, M21 bought from the original owners father in 2001. The '73 is an L75 (ordered as an LS2), M40 I've bought twice. First time in 1986 and second time for keeps in May 1990. Both unrestored originals but high miles.
The Following User Says Thank You to Transamric For This Useful Post:
Old 11-24-2021, 03:14 AM
jhein's Avatar
Well, a sleeve is a kind of a spacer that's just a cylinder shaped kinda spacer. So right on...
