Old 11-25-2021, 06:04 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
Default air cleaner size under a stock hood
One of the things I want to do this winter is change over the intake manifold and install a stock height single 4 barrel manifold (currently an offy dual quad) and have a play with quadrajet and holley carbs.
I will need to buy an air cleaner and I am curious what fits under the hood of a 68 GTO. Anyone use a round 16 inch air cleaner with a 4 inch element?
Or a round 14 inch with a 4 inch element?
1968 - Pontiac GTO
The Following User Says Thank You to Charlie Brengun For This Useful Post:
Old 11-25-2021, 07:33 AM
Carousel72TRed's Avatar
Carousel72TRed Carousel72TRed is offline
I believe both of those air cleaners you mentioned will be fine with your car. I have a Holley on mine(69 GTO Ram Air Hood). With the Holley I have to use a spacer on top of the carburetor to prevent the air cleaner base from interfering with the throttle linkage. I have used both the 16” or the 14”.
Old 11-25-2021, 05:17 PM
here was my test method in my pre "keep it bone stock" days:
1... Measure the distance in a straight line from the endura nose lip to the air cleaner stud on your carb.
2... Measure the same distance from the front center tip of the hood back towards the center of the firewall and mark that point on the underside of the hood.
3... form a vertical rod of playdoh or silly putty and place it on the top of your stock air cleaner lid as close to the stud as possible, and place a small piece of paper over it. (so it doesn't stick to the hood)
4... close the hood and reopen the hood
5... measure the height of the putty above the top of the air cleaner
6... mark out the circumference of the aircleaner you plan to install from the mark you made on the underside of the hood.
7... eye ball the height variation of the under hood surface to see of any potential height issues and re measure those spots with putty if needed.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 11-25-2021, 07:39 PM
Ab69 Ab69 is offline
Should be good with a 14 x 3 .
Old 11-26-2021, 11:10 AM
Thanks for the responses all!
1968 - Pontiac GTO
Thread Tools
Display Modes
