Old 11-26-2021, 11:04 AM
Mo's Avatar
Mo Mo is offline
Default Black Friday Special VS Turbo
I'm looking to purchase a single turbo for a , 462, standard E heads, 9:1, roller turbo cam, forged internals, log style SS headers, FI, pump gas(or E-85 if I can find a stable source) in a 3800lb 76 T/A. 6500 red line. 10.0 ET power but mostly a street car. It's going for $899
Is the turbo below too big? I see others mention in other posts using other turbos but don't always mention the actual turbo specs.
https://turbo4less.com/product/vsr-8...k-friday-deal/
Systems under stress fail catastrophically
Old 11-26-2021, 11:21 AM
Mo's Avatar
Mo Mo is offline
VSR 88mm Next Gen T6 1.58ar Billet unit with 103mm Turbine wheel
Specs
Compressor Wheel Inducer: 88mm 7+7 wheel design
V-band Compressor outlet Std S400 Vband
Turbine Wheel: 103mm
Turbine Housing T6 1.32 Divided 5″ Marmon V-band discharge
Oil inlet threaded 1/4npt
Old 11-26-2021, 11:32 AM
Tom Vaught's Avatar
Boost Engineer
You need a price in the post Mo. You have 1100 posts and should know the rules.
TV.
Old 11-26-2021, 11:45 AM
Mo's Avatar
Mo Mo is offline
Hi Tom, sorry for the confusion, I'm not selling, looking to possibly buy for a single turbo deal. VS is running a "sale" and I saw this one posted. Hope you had a nice Thanksgiving.
I edited the original post.
Old 11-26-2021, 01:11 PM
Tom Vaught's Avatar
Boost Engineer
My basement is bigger than their company location, apparently according to Google Maps.
That being said, obviously off shore Chinese stuff. I would look at Richard Holdeners
Website and see if he has ever dynoed any of the VSR 88mm turbos in the past.
The prices are twice what he recommends for a good street turbo for your intended application.
Quote: I'm looking to purchase a single turbo for a , 462, standard E heads, 9:1, roller turbo cam, forged internals, log style SS headers, FI, pump gas(or E-85 if I can find a stable source) in a 3800lb 76 T/A. 6500 red line. 10.0 ET power but mostly a street car. It's going for $899
Just saying.
Tom V.
Old 11-26-2021, 06:32 PM
Mo's Avatar
Mo Mo is offline
Richard has dynoed the VS against a BW 470 and both performed as expected. Used his 4.8 LS test mule motor. Smaller turbos, of course. T4. The turbo in question has a billet impeller and they tend to be more expensive than the standard BW turbo. The S470 that I’ve seen are around $550 To $750 range depending, so I think it’s a reasonable price. Wondering how that hot side A/R would spool on my combo.
Old 11-26-2021, 10:57 PM
70 bird's Avatar
70 bird 70 bird is offline
I have an s488 1.32 a/r with a 98mm turbine wheel on my 462. Mine spools a bit slow with a tight converter and a 3.08 gear. I am overall happy with the turbo but I do have a borg warner turbine and center section with a billet aftermarket compressor wheel. I dont know of the quality of the unit you posted.
Old 11-26-2021, 11:15 PM
Tom Vaught's Avatar
Boost Engineer
It is a flip of the coin on whether the engine will like it or not.
I have purchased turbos in the S-400 series with prices all over the place.
You are going to run a 455 turbo, this video might be of some help.
https://www.youtube.com/watch?v=3hWgN-5ZLa8
Tom V.
Old 11-27-2021, 03:23 AM
R 70 Judge's Avatar
I’m no turbo guru but I believe this one may spool faster and be more responsive on a 462. It’s a T4 instead of a T6 so it’s probably a bit easier to package as well. 1.24ar vs a 1.58ar.
https://turbo4less.com/product/vsr-8...88-t4-1-25-ar/
VSR 88mm T4 1.25ar 88mm Compressor 96×88 Turbine 1.25 T4
Compressor: 88/124
Turbine: 96×88
Turbine Options: 1.25AR divided T4
Compressor Outlet : S400 Vband
Turbine Outlet: 4″ Std Discharge
Inlet Flange: T4 divided
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 11-27-2021, 07:29 PM
Curtis Slowe Curtis Slowe is offline
I think that turbo would have you in great shape. 10.0's won't be a problem. You won't need 6,500rpm to do it. One of my buddies runs the VS 94mm with a bigger hotside on a 5.3 and goes 4's. The price is right....I'd do it. Almost bought their 94mm myself. It's not a Garrett or Precision but my buddies has stood up well so far. 3 left I think. Lol
Thinking of whether to go T4 or T6 I'd go T6. Backpressure will climb pretty quick. My $.02.
Old 11-28-2021, 12:14 AM
turbo69bird's Avatar
https://www.yellowbullet.com/threads...dback.2022386/
I’d say take a look at some of the old info at PZ as well, in the forced induction/ turbo builds forum. Im not over there pretty much anymore, but still some good info on there .
I run a turbonetics t88 thumper ball bearing (old old turbo) on a factory (but we’ll prepped) 2 bolt 455 block stock crank solid lifter cam and iron smog heads and get in the 9s fairly easily in fact I shift at 5600 rpm . I Have built the same set up with an s475 and run the same or better times.
Too big is always better than too small. Heat is the enemy and a fat lazy tune is better than the alternative. The goal should be to make it live and sneak up on the tune, but even then stay fat and lazy for longevity.
Turbos like to be loaded. So less gear multiplication is better. To a point.
960 HP @ 11 psi, 9.70 at 146.
Old 11-28-2021, 10:51 AM
Mo's Avatar
Mo Mo is offline
Thanks for the feedback and links to the sites and videos. I'm thinking the bigger A/R may work out since the car will have a bunch of torque down low. Backpressure was a common theme with those 4.8-6.0 motors and the smaller hot side A/R. That said it is a big turbo and packaging will be interesting for sure.
