Old 11-07-2021, 08:51 PM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default 63 G/P Reverb
Does anyone have a picture of how and where the reverb box is mounted in the trunk?
Thanks KC
Old 11-07-2021, 09:50 PM
gtoguys gtoguys is offline
I don't have a picture, but I was told by the 1963 GP Chapter tech, that the reverb box goes on the right rear wheel housing. I have a 63 GP also and wanted to put in a reverb. When I looked at that location, I said no way! The screw tips would be near the tire. I mounted mine on the rear seat divider panel. It works fine mounted there and is out of site and out of the way if you put something big in the trunk.
Old 11-08-2021, 09:43 AM
Default reverb
I looked and did not see any old mounting holes on the right wheel house, my car originally came with the reverb.
My 67 GTO has the reverb mounted to the underside of the package tray area in the trunk on the drivers side.
Thanks for the response. KC
Old 11-08-2021, 02:43 PM
1965gp 1965gp is offline
I want to say it is on the trunk floor below the package tray on the drivers side.
Old 11-08-2021, 07:37 PM
Default reverb
I climbed in the trunk today and located a small wire loom bracket on the upper right side wheel house so I looked around in that area and found 2 small holes in the right side rear seat brace in the same area as the small wire loom bracket. Looks like I stumbled on to the original mounting location.
Thanks KC
Old 11-08-2021, 10:53 PM
When you get the reverb mounted, can you take a picture of the mount location? I would like, as well as others, to know where it should be.
Old 12-14-2021, 05:03 PM
Default Reverb
Got the reverb mounted today, I`m pretty sure this is the factory location. There are holes to mount the unit and there is a small bracket to hold the wire harness.
ID:	579642   Click image for larger version
ID:	579643   Click image for larger version
Old 12-14-2021, 09:49 PM
That's not where I was told, but it makes more sense to put it there. Thanks for the pictures. It mounts at an angle of all things. Like they say, a picture is worth a thousand words!
Old 12-15-2021, 09:41 AM
Mounting holes and wire bracket were already there so this looks like the right spot, has to be on an angle, won`t fit there straight up & down.
Old 12-15-2021, 11:51 AM
I forgot to add, in the spring, I will move mine to the correct spot. Thanks again for the pictures.
Old 12-31-2021, 03:25 PM
389 389 is offline
It goes on the higher section under the window behind the rear seat. I would put it on a piece of rubber to slow down vibrations.
Old 01-01-2022, 01:10 PM
Default ?
Factory holes tell the story, no factory holes in the location you say.
Old 01-02-2022, 07:05 PM
gary bennett's Avatar
gary bennett gary bennett is offline
I screwed mine to the floor right behind the back seat.
DBANDGB
Old 04-18-2022, 01:18 AM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
I pulled a reverb and power antenna out of a 64 Bonneville about 7 years ago....and IIRC....the box was mounted on the right side behind trunk divider parallel and just below parcel shelf...
I'm sure I took some pics......but finding them could be a challenge.
