My 421 Block Isn’t Following The Rule
Hi,
It was pointed out to me that my 421 block doesn’t have the straight across machined pad under the cylinder head but is scalloped like the 389. It’s a 1966 421, YH code, has the transfer lug, 2 freeze plugs on each side, has factory 4 bolt w/ 3.25” mains and a factory 4” stroke crank. Any reason why the machined area on the passenger side is scalloped and not straight across?
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
I have learned to never say never with anything out of the foundry.I posted on here that I owned a 400 RA V block with a transfer lug.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
I have 3 421 Blocks. None of them have the straight deck or straight front timing cover. 2 Blocks are 1966 castings one with YH and one YK, 1 block is a SR block cast in 1967 YH (428 block) but has 3 freeze plugs and is restamped the 421 casting number and has the 421 bore size.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
The Following User Says Thank You to Mike Davis For This Useful Post: | ||
A friend of mine has a 66 421 and it is scalloped just like yours . I have a 65 421 and it is straight across.
The Following User Says Thank You to ANDYA For This Useful Post: | ||
What's the block casting code and date code on it?
Had to go back to find a pic.
Thanks!
The Following User Says Thank You to johnta1 For This Useful Post: | ||
I can’t seem to keep the attached pics from rotating.
They’re clearer though
I have never seen a scalloped block with the radius you have on your block. "scalloped surface" should be cast not machined. Tom V.
I’m seeing a cast finish on the scalloped area.
Enlarge the picture and look closer.
My 66 YH 421 and my 66 YK are scalloped, but my 65 WG is straight. I just figured it was a 66 thing.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
I am going by the extremely sharp edge of the scallop in Post #1 vs the 4th picture in post #8. The scallop & texture looks "created" to me in Post #1 vs the rough cast (Factory casting) shape/texture in Post #8.
are you saying the factory created these scallops?
If you are replying to my post, the factory cast up many many 421 blocks with a straight across block surface next to where the head gasket is.
389 engines had the cast "scallop" in the passenger side of the blocks and were not straight across. Years ago people would cut off the Transfer Lug on the back of the 421 engines and tell people that the engine was a 389 engine, (no transfer lug visible) but they missed the straight across block surface detail which still allowed knowledgeable people to easily spot the 421 block being used. I know little about the 1966 421 blocks but I do know that if GM would remove 24 inches of heater hose to save money, they were not about to throw-away 1000s of good 389 castings vs having the raw castings machined .030" overbore and removing additional metal in the crankshaft main bearings bores and putting on 4 bolt main caps and machining the blocks for those 4 bolt main caps and bore size. So my opinion is some of the last 389 blocks were used to fill the 421 orders as GM would be using the new 428 blocks on the 428 engines and occasionally a 3 freeze plug 428 block casting on a 421 build. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
My '66 YH 421 is scalloped and my '65 YH 421 is straight across.
The Following User Says Thank You to John Milner For This Useful Post: | ||
The 66 421 might be a couple of pounds lighter, but they weren't using 389 blocks.
Unfortunately, Tom is highly suspicious of anything outside of his comfort zone. Quote:
Interesting thread!
Need some examples of the straight across block for 1966. Any of these have the small 'x' before the engine code? (WJ, YH etc) Also looks like the block codes are all 9782611 in this thread I think. Maybe need a poll of the passenger side straight edge or the 'v' cut.
Here is a 66 WJ 421 with correct 421 casting on the pad and side that also has the scallop. So they either had to change the casting numbers when the block was poured or change the scallop.
They do list 2 casting numbers for the 66 421 but the numbers cast into the side would have had to be done at the foundry and is different than any 389. Why would they pour a 389 block with new casting numbers vs just pouring a 421 casting? 421 cid 9778791(E) 421 cid 9782611(L) https://www.ebay.com/itm/1966-PONTIA...5.c10#viTabs_0
on parts cast. They did that deal every year on the cylinder heads. New interesting history for the Pontiac Engines. Tom V.
I gave away two 421 blocks to a Pontiac friend, at the end of last year but one was for sure a 1964 370 HP "45B" block and the other one was a 1965 356 HP WH block (if I remember correctly). Both had the flat deck, no scallop. Again I know little about 1966 421 blocks.
