Bushings and Gasket; Accelerator pedal lever assembly '64 GTO
Does anyone know if these bushings and gasket (red arrows) are reproduced? The support ass'y mounts on the engine side of the firewall. The bushings are about 0.375 ID x 0.457 OD. I've tried OPGI's Accelerator Rod Bushings but they are too small.
I don't think they are reproduced. I believe bushings are the same from 64-67. You might find some in the parts wanted forum.. Gasket can easily be made.
Your best bet is to hit a supply store or site like McMaster-Carr and look for nylon flanged sleeve bearings. Just accurately measure the bracket ID and the pedal rod OD you have and compare with the available offerings here:
https://www.mcmaster.com/nylon-bushi...eeve-bearings/ |
The Following User Says Thank You to ZnbOlds455 For This Useful Post: | ||
Thanks for the info guys. I was pretty sure they are not reproduced but I was hoping someone had located a source. I completely forgot about McMaster-Carr. We utilized them in the HVAC trade a lot when there was a warehouse in town.
