Old 05-22-2023, 09:59 PM
beemergary's Avatar
Default TH400 troubles-help
Drove 350mi to a NDRL to race NSS with the 63 tempest. First pass won't shift at WOT. Get back to pits and trans hot. Hrs. later try manually shifting instead of usually letting it do its own thing with govenor set for around 5,500. Won't shift at WOT and notice slipping on return road and its getting hot again. Pull in trailor-shut off and come up short so decide to just push it the last 1 1/2 ft. Won't push-and 1/2 hr. later will. DUH
The Following User Says Thank You to beemergary For This Useful Post:
Old 05-23-2023, 06:33 AM
steve25 steve25 is online now
Something is seasing up it would seem and it's very likely to be a issue that can't be fixed with the trans in the car.
Old 05-23-2023, 07:45 AM
But drove 350 miles just fine?
Low fluid level? Vac mod line burnt open? Pink fluid?
Old 05-23-2023, 08:49 AM
beemergary's Avatar
Miss wrote it was in a trailor.
