Old 06-01-2016, 08:47 AM
dedsleds's Avatar
dedsleds dedsleds is offline
Thumbs up 1959 PONTIAC CATALINA SEDAN 389 w/TRI-POWER 12,000 obo
****PLEASE READ ALL OF THE AD! EVERYTHING IS EXPLAINED IN THE AD! THANKS!
SOLID TEXAS CAR! FRAME SOLID, & BODY PANELS AND BUMPERS SOLID! FLOORS 95% SOLID, BUT WINDSHIELD LEAKS, SOME HOLES IN THE FLOOR, SMALLER ONES. FEW IN TRUNK, SMALLER ALSO. DAMAGE TO 1/4 IS SHOWN IN THE PICS! HAVE NOS PATCH PANEL AND BUMPER END TO INCLUDE. 65,000 MILE CAR, I BELIEVE THIS TO BE TRUE, AS IT HAS BEEN OFF THE ROAD SINCE THE MID 1990's.
389 TRI-POWER, HYDRAMATIC TRANS, 3.08 OPEN REAR (ORIGINALLY A 2BRL CAR) PS, PB, TRUNK LID REEL OUT LIGHT (LIGHTING PACKAGE), A/C PACKAGE (RARE ....LESS THAN 8% OF THE 100,000 TOTAL CATALINA MODEL LINE HAD THE $433.00 OPTION)
389 REBUILT:
ENGINE W/30 OVER PISTONS W/NEW MOLY RINGS
VERY MILD CAM/LIFTERS
NEW CAM BEARINGS AND FREEZE PLUGS
8 NEW INTAKE VALVES/PLUS A VALVE JOB
NEW REAR SEAL
NEW ROD/MAIN BEARINGS
GRIND/POLISH CRANK
RECONDITION RODS
HEADS/BLOCK MAGNAFLUXED
ALL NEW BELTS
ALL NEW GASKET SET (FELPRO)
NEW TEMP SENSOR
HAVE FRESH OIL AND OIL FILER CARTRIDGE (AC)
TRI-POWER:
REBUILT W/UPGRADED CARB KITS (SOON THE END CARB BASES ARE BEING SENT OUT TO SEAL BETTER) CORRECT VACUUM TEE AND LINES
CORRECT 1959 FUEL LINE/BLOCK AND LINKAGE, ALL FUNCTIONS FINE
NEWER AIR FILTERS
NEW FILTER AND PUMP
COOLING:
REBUILT FACTORY RADIATOR, NEW WATER PUMP AND HOSES, NEW PETCOCK....WILL NEED A HEATER CORE....LEAKED AND HAS BEEN BYPASSED
CHARGING SYSTEM:
12V SYSTEM ALL CLEANED AND FUNCTIONS PROPERLY
BRAND NEW BATTERY
ALL BODY/CHASSIS GROUNDS CLEANED UP AND REINSTALLED
BRAKES:
HAD TO REMOVE PW BOOSTER, CONVERTED TO MANUAL BRAKES
NEW REAR HOSE
ALL BRAKE CYLINDERS SERVICED AND LINES FLUSHED
NEW MASTER CYLINDER
EXHAUST:
BRAND NEW 1 7/8 DUAL EXHAUST SYSTEM AND GASKETS
EXHAUST MANIFOLDS POWER COATED
HEAT RISER FUNCTIONS PROPERLY
SOUNDS GOOD
TRANSMISSION:
NEW GASKET AND FLUSHED SYSTEM, CLEANED SCREEN, ADDED NEW FLUID AND SEAL SWELLER....SO FAR NO LEAKS, SHIFTS FINE. COOLING LINES TO RADIATOR CORRECTLY REPAIRED ALSO.
RARE A/C SYSTEM:
FLUSHED/CHARGED, BUT COMPRESSOR TOOK A **** ON US, STILL HOLDING A CHARGE. BOUGHT 3 NEW VACUUM PODS FOR FIREWALL.
BODY:
RARE ROYAL AMETHYST COLOR, RARE TINTED GLASS, ALL TRIM IS THERE, SOME DENTS ON THE TRIM HERE AND THERE. PASS SIDE REAR 1/4 DAMAGE. I HAVE NOS PANEL FOR THAT AND A NICE USED BUMPER END TO INCLUDE. I HAVE AN OK TRUNK LID TRIM PIECE, JUST CAN'T FIND THE CLIPS TO INSTALL IT! SOLID FRAME, CAB STILL SEE ITHE FACTORY INK STAMPING ON THE FRAME (PART#). WINDSHIELD CRACKED, ALTHOUGH I HAVE A OEM CLEAR ONE TO INCLUDE. ALL LIGHTS WORK.
SUSPENSION:
NO ISSUES, CAR RIDES LIKE IT IS ON A CLOUD. FRONT END GREASED, & NEW SEAL ON POWER STEERING GEAR BOX. CAR WILL BE SOLD WITH THE ORIGINAL 14" WHEELS/HUBCAPS SET TIRES. I AM KEEPING RALLY 2's. FOR MY OTHER CAR!!!!!!!!!
INTERIOR:
AM RADIO NOT WORKING
ALL DASH LIGHTS WORK
SWITCHES WORK
SPEEDOMETER AND GAUGES ALL WORK
DASH CLEAN AS WELL AS THE STEERING WHEEL
TURN SIGNAL SWITCH IS A LITTLE GOFFY, WORKS BUT ACTS UP ONCE IN A WHILE
NO CARPET! MAY OR MAY NOT ORDER THAT I WILL NE POR-15-ING THE FLOORS SOON!
SEATS ARE OK BUT RIPPED
DOOR PANELS OK
CHROME INTERIOR PIECE IN GOOD SHAPE
ALL WINDOWS ROLL DOWN
WILL NEED HEAD LINER
A SOLID CAR THAT RIDES NICE. NOT HACKED UP, AND ANYTHING REDONE NY US HAS BEEN DONE TO AS CLOSE AS FACTORY AS POSSIBLE. RAN OUT OF MONEY, MOST OF THE HARD STUFF HAS BEEN DONE! HAVE ALL RECPTS TO PROVE WORK DONE. ALL OF THIS IS FRESH! LESS THAN 400 MILES ON EVERYTHING DONE!!1
ID:	429633   Click image for larger version
ID:	429634   Click image for larger version
ID:	429635   Click image for larger version
ID:	429636   Click image for larger version
1959 catalina 4dr a/c car
1970 gp strip car ...
1972 gp j 455/4
1971 bonneville hearse 455/4
1972 grand safari wagon 6 pass 455/4
1995 Firebird Formula 5.7 convertible
2002 gp 40th anniv. SC V6
2003 gmc sierra 2500hd 8.1 liter
***LIKE MY FACEBOOK PAGE https://www.facebook.com/GratefulParts***
http://stores.shop.ebay.com/GRATEFUL...__W0QQ_armrsZ1
Old 06-01-2016, 11:09 AM
63gpman's Avatar
63gpman 63gpman is offline
Nice ride, did I miss the price? Good luck with the sale!!
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 06-01-2016, 11:18 AM
dedsleds's Avatar
12,000 obo
thanks
1972 gp j 455/4
