Old 07-09-2023, 09:25 PM
Default Who knows anything about 69 Birds with Real RamAir Induction ?
Here is a link to one that recently sold here on PY https://forums.maxperformanceinc.com...d.php?t=865889
Induction looks like 1968 stuff
Is that correct for 1969 also ?
How many Ram3 Induction 69 Birds were built ?
Old 07-09-2023, 10:01 PM
Held for Ransom's Avatar
No 611, Hood Ram Air Inlet. 731, Air Cleaner, Heavy Duty is like a regular Firebird 4-bbl air cleaner with a dual stage filter.
348 is the RA engine though.
So long, farewell.
Old 07-10-2023, 12:42 AM
1qikta's Avatar
1qikta 1qikta is offline
It was an interesting car. With the invoice credits the ram air cleaner was prob a dealer add on. The hand written clerical notes + and - tells some of the story.
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 07-10-2023, 04:22 AM
Tim john Tim john is offline
Interesting "gate" style valve ? on the heater hose line located by the passenger side inner wheel well.
Tim john---
Old 07-10-2023, 09:51 AM
Tim john---
He was probably a plumber, had some leftover fittings
Old 07-10-2023, 10:09 AM
That turns off the hot water going to the heater core in summer.
Some of us gearheads growing up would bypass the heater core in summer too keep inside the car cooler.
Old 07-10-2023, 01:30 PM
It is an odd invoice , and an odd credit memo.
It was likely one of the first built "WQ engined , 348 , HO , RA" cars in the 69 model year.
Maybe that is why it has the invoice blurb R/A .
The GTO wasn't available with WS Ram3 engine until this same time period in Oct 68.
Could you tell me what the credit memo says ? Can't read it all.
-348 , +345 _ _ _ 556 (?) _ _ _ _ _ 11/16/68
CMD 202300 11/16/68
I found 3 invoices for #348 engine cars and none had Saf-T-Trac
Was a posi rear part of #348 option ?
One of them even has Performance Axle Ratio option listed ,,, but no Posi listed . (?)
Here is another Oct 68 #348 car listing it as R/A
Found a July 69 #348 car listing it as HO
Seems like I am starting to remember this ordeal from other threads in the past.
Except I don't understand the Posi dilemma yet.
Driver Controlled RamAir below cig lighter
Old 07-10-2023, 05:44 PM
Was this Midnight Green car a WQ engine ,, or a WZ engine ?
Old 07-10-2023, 06:49 PM
1qikta's Avatar
It was a WQ engine with 48 heads. Had the oil filter adapter for long branches. RAIII intake. 7029268 carb.
ID:	615749   Click image for larger version
The Following User Says Thank You to 1qikta For This Useful Post:
Old 07-10-2023, 07:13 PM
1qikta's Avatar
The HO option was called RA on the invoice up until December of 1968. After that it had the HO call out.
Old 07-10-2023, 07:34 PM
Thank you for your info about the car 1qikta .
Do you know if the car had a Posi rear ?
The other 2 (automatics) I posted invoices for both claimed to have Posi rears.
Old 07-10-2023, 08:14 PM
Another HO PHS posted here...
https://forums.maxperformanceinc.com...d.php?t=517870
Reach out to member MikeNoun for more insight on RA/HO's.
https://pontiacwindowstickers.com/pr...sticker-early/
So long, farewell.
Old 07-10-2023, 08:19 PM
I wonder if the 345 is supposed to be 354?
(354 is 4 speed close ratio tranny, 345 is 428 HO)
I also thought it looked like 348 & 345 ...
1qikta, is the block date code G178?
Old 07-10-2023, 08:47 PM
1qikta's Avatar
The original rear end was gone. The owner had upgraded to an 8.5 10 bolt with traction bars, the car had a lot of drag racing evidence.
Old 07-10-2023, 08:51 PM
1qikta's Avatar
Didn’t get the block but the intake and heads were
Heads H208
Intake H138
Old 07-10-2023, 08:53 PM
345 is the Firebird 400 option. You had to order that to also order the 348. I don't know what else would be added to equal the total price. WQ is the 348 (400/4 speed) engine code.
So long, farewell.
Old 07-10-2023, 11:11 PM
Has anyone ever owned a documented 69 Bird Ram3 with Functional RamAir that was a well kept complete car ?
I have never seen one.
Production must be as low - or lower - than Ram4 Birds
Old 07-12-2023, 11:26 PM
rdl's Avatar
rdl rdl is offline
Rotella’s book claims that L74 production was 1,509 units for all 1969 Firebirds. 642 units were installed in T/As, leaving 867 units. The T42 (611) option was installed in 877 cars. 102 L67 equipped Firebirds (non-T/A) received the T42 as included. That leaves 775 units to be accounted for. If the T/A hood inlet system counts as a T42, that leaves 78 L74-T42 cars produced. The remaining 789 were L74 H/O cars.
'69 R/A III Firebird Convertible
14.0s @ 100.8mph AMA/OEM/OER
The Following User Says Thank You to rdl For This Useful Post:
Old 07-13-2023, 09:08 AM
Thanks for that info rdl .
102 RamAir 4 cars with Induction
78 RamAir 3 cars with Induction
789 HO / #348 cars without Induction
Old 07-16-2023, 12:36 AM
68hotbird 68hotbird is offline
Default 69 611ra inlet
Tim Smolinski had a black fairly original ra3 611 code car. Was black on black he had it for sale recently. Looked like a very nice car. I owned a white 611 ra inlet car in 2006 or 2007 but it was very rough and all of the ram parts were gone except the original hood. The earliest 611 car documented so far was built in march of 1969. There are several RA IV birds built in late February including mine. Looks like there may have been a few ra IV cars built before the first production ra 3 or 611 ra inlet car. The 611 Ram air inlet package was delayed and was not available to order until Jan. 21, 1969 per an intercompany memo sent out to dealers. There were two other memos announcing the 611 was available to order one in November and one in December but they were both canceled with an additional memo. I know the Jan 21st, memo was good as I have the hand written order form for my Ram air IV and it was ordered on Jan. 22nd on a rush sold order. Sorry for the long post there are pictures of the 611 memos in Rockys book.
The Following 2 Users Say Thank You to 68hotbird For This Useful Post:
