Old 06-04-2023, 08:55 PM
beemergary's Avatar
Default Torque Converter Question
What's the signs it maybe going bad? Thanks
Old 06-05-2023, 06:14 AM
steve25 steve25 is offline
Other then a ballooning condition that usually is not the converters fault, anything else that can go wrong with a converter means it's dumping trash back into the trans.
I would not run the motor or drive the car any more until you drop the tranny pan and look for crap in the pan and filter.
Old 06-05-2023, 07:41 AM
Formulas Formulas is offline
I had a stock one go bad at idle at a stop light, loud screech slight grind noise lost stall was almost direct drive after that, not far from home turned around returned to base shutting it down at stop lights
got a new converter dropped the pan saw glitter changed oil and filter put a few rare earth nagnets in the pan about 1 inch round .100 thick drove it for 4 or 5 days dropped pan cleaned magnets changed filter and drove many thousands of miles after that
The Following 2 Users Say Thank You to Formulas For This Useful Post:
Old 06-06-2023, 12:01 AM
blueghoast's Avatar
You'll start seeing a drop in ET and MPH and probly notice that
it just doen't feel the same as before, it can start out lightly off
and start getting worst from there. like said before, check pan.
GT
Old 06-06-2023, 01:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Stall speed getting erratic. I had one that laid over a bunch of fins. And only a 400 HP motor!
Skip Fix
