What Hydraulic Roller Cam in 467
I know there have been many posts on here regarding what Hydraulic Roller Cam to use. Old Faithful, Stump Puller ETC.
My car is 1964 Pontiac Grand Prix 4 speed manual, 4.10 gears ( Probably switching to 3.64 ) Motor will be 467 CI KRE 310CFM Heads, 11:1 Compression Torker 2 with 950HP 1 inch spacer. Will be using Long Branch Manifolds instead of 4 tube headers so I'm sure this will affect cam choice Overlap etc. Thanks, Rich |
I would go no smaller than the OF grind and install it at 109-110ICL. Same basic combo I have, mine is closer to 11.3 to 1 compression and using the OF cam on a 112LSA. It's been flawless now since 2009 on a steady diet of pump gas, even runs OK on 87 octane w/o pinging but it will "run-on" once in a while on a really hot summer day fully heat soaked so I typically keep 91-93 octane in it. The ICL came in at 109.5 so I just left it there and glad I did. Idles nearly dead smooth with just a hint or "attitude". Makes 13.5" vacuum at 700rpm's with only 10 degrees initial timing.
Compression is your friend with these things and allows for bigger cams with less negatives. However a small cam and high compression can get you into trouble in a hurry and little cams aren't going to take advantage of 310cfm head flow either......FWIW......Cliff
Anyway - my old cam failed on low end power (76 TA/474 - 3.23 gears and ST10) and the OF at 107 is a torque monster. I love it. Street car - shift by 5500 or so. Very much recommend that cam. |
Can't beat the OF in a 455. It's a beast and sounds amazing. Wife's 71 TA 455 with eddy heads and 4l80e with 3.08's runs 11.60's @ 3950lbs. My 66 Lemans 461 with Kaufman d-ports @ 3900lbs runs 12.00. Your going to love it.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
Its also a very smooth street cam. Everybody always talks about the performance of the cam...but the street manners are great.
I think very difficult to go wrong with any of the SD HR cams assuming consistent with rest of the build. I have the equivalent of the RP in my 469 RA IV with mildly ported 722 heads 9.50:1 CR M21, 3.90 rear. A little bit unhappy below 1700/1800 RPM - could use a little more CR - but above there, phenomenal throttle response, unlimited torque.
x2 on the OF in my 467 e-head 10:7 motor. runs great on the street on pump gas & does consistent low 11's. great cam.
The OP didn't really say if the cam needed to be stop 'n' go traffic friendly. Just 4 speed with a possible rear gear swap. Clay |
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post: | ||
The last 467 I recently built I went with a custom ground camshaft from Paul using voodoo lobes that is very close to Old Faithful specs. 239/243 @ .050 and a pinch over .600 lift and on a 112 LSA. I installed it at a 106.25 ICL. Engine is 9.98:1 compression with iron heads. Dyno'd with 91 pump gas.
Stock intake, carb, and exhaust manifolds and it made 507/571 on the dyno and idles with only a slight attitude and makes 13 inches of vacuum up here at 5,000 feet elevation. Car has working AC and is an automatic with a custom converter through Cliff that drives fantastic. Easily a daily driven car if one wanted to, behaves nicely. I'd lean on what others said, with an engine this size I really wouldn't even look at a camshaft any smaller than 230's @ .050 intake duration. The 455's gobble that up like it's not even there. I don't even consider a cam rambunctious in these engines until you start getting up closer to 250 @ .050. Last edited by Formulajones; 02-21-2020 at 11:20 AM. |
my car is an auto with 3.23 gears & does great in stop & go traffic & all city & highway driving. in a bigger cube engine like a 467, the OF cam is very docile & idles like a much smaller cam.
My thoughts mirror the other guys thoughts on cam size. But rather than compcams we are using “3823” hyd roller profiles from Bullet. I believe they are basically Ultradyne profiles converted to computerize profiles. I think the smallest one is 236 @.050 and the largest ones are 260s as .050 and they all have .3823 lobe lift. Makes for a range of .573-.631 for lift depending on the rocker arm ratio.
FWIW, I like the lift range, and I like the way the 3823 cams are designed for the lash ramp coming off the base circle. A kind of example of the difference between the design like a comp Magnum HR and the Bullets is running a solid roller hybrid on one of the Magnums, to quiet the noise down most guys lash them to .005-.008. Compared to the Bullet is .008-.011. It is a difference in how the profile comes off the base circle. The XE and XE FI are more aggressive yet. Not trying to bash a compcam or Old faithful what so ever. The comps like the OF are great cams. Imo, if you are running plenty of compression, on pump gas, on the street, that slower ramp won’t hurt you at all. Plus to lift as shut the valve a little slower will likely make it little quieter, maybe even more dependable. Last edited by Jay S; 02-21-2020 at 11:20 AM. Reason: Edit |
I think that is correct. IRC there are some changes to the profile that occurred when Bullet transferred the designs to their software. But they are based from a design Harold did. I would not be surprise if the profile in your engine was similar in the way it came off the base circle. Harold seemed to design that part of the profile pretty consistently, his later designs like the voodoos seemed to have more duration at and above .2”.
Three similar hydraulic roller intake lobes....
Comp Magnum High Lift #3122B (Old Faithful) 289 236 160 .3800" 0.570" UltraDyne #HR12 288 234 155 .3533" 0.530" Comp QXI #13451 289 237 158 .3950" 0.593" The QXI Series lobe profiles are designed to provide the highest available valve lift for modern cylinder head ports, along with excellent stability and the broadest possible power range in hydraulic roller applications. .
To reinforce what Cliff says keep in mind that in motors like the 455 who's stroke is bigger then it's Bore, cylinder pressure will rise much faster then a over square motor and on pump gas you need to bleed that off with the Cam.
I forgot to add Comp XE lobe 3196
288 236 162 .3900" 0.585" This is the intake lobe Dave Bisschop uses on his revised Old Faithful cam (OF2). However Dave apparently orders it with a "B" suffix code after the lobe number as he does on the older OF cam. By doing so the duration can vary slightly by 1-2 degrees. And the lobe lift increases by 0.001". Keep in mind a 2-valve ported cylinder head responds to valve lift without a sacrifice of idle and low speed qualities. Bottom line, the engine wants all the lift it can and thrives on it so run as much as mechanically achievable or unless prohibitive because of cost limitations. .
Only when the Intake tract as a whole can provide increasing air flow levels when adding more valve lift, in regards to your last paragraph.
Other wise once port velocity drops off too low from porting the head and increasing the heads minimum port area Torque output levels at low speed will fall off a cliff!
OK. But note the OP will be using ported KRE heads that flow well above .600" lift and have less intake runner volume than a similar ported Edelbrock head. .
I have been using this cam with 1.65 rockers in my 467. Been happy so far.
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
head flow vs cam lift?
https://www.yellowbullet.com/threads...m-lift.394221/ Cam lift vs. cylinder head flow http://nastyz28.com/threads/cam-lift...ad-flow.37265/ .
