Old 02-06-2021, 01:34 AM
jarretts70 jarretts70 is offline
Default Possible 1969 Judge
I may have the chance to pick up a 69 that is claimed to be a Judge. Project car that has been pretty gutted, including the cowl tag. The vin is still there, its a real 242 GTO. Its a Pontiac plant car, and the vin is fairly high - 343xxx. The high vin leads me to believe it could have been built late enough in the year to be a Judge, but no cowl tag to show the date....I know I can get a PHS, but before I do I want to know if Judges were built at Pontiac plant. If not then I'm not going to pursue it further...Thanks
Old 02-06-2021, 02:14 AM
Yes they did eventually do 69 Judges at the Pontiac Plant too.
So its better that its a late car than an early car - for that reason .
Quick check on some files found a Pontiac Plant Judge in the high 2xxxxx range invoiced in late April. So the 343xxx is just like you suspected - LateLate
There's a hole for the RamAir cable in the firewall that non-RA cars won't have.
Is about as deep as you can dig - into the car itself.
Buildsheets don't seem to be existent for 69 P-Plant GTO/Judge - so probably not much hope in dropping the tank to look first.
Good Luck with it
Old 02-06-2021, 12:25 PM
Thanks Baron, the firewall hole is a good clue. Even if it turned out to be a non-Judge it might still be worth it if its a ram air car.
To be honest I'm not holding my breath it turns out to be be anything, but fingers crossed...
Old 02-06-2021, 01:27 PM
What did the original color seem to be on the car ?
What i meant by that is Bsheets aren't being found in those cars.
In all my Bsheet collecting past 15 years have 0 from 69 P-Plant GTO/Judge.
However, history has proven that there is usually just about always at least 1 exception to everything , somewhere.
Old 02-06-2021, 03:59 PM
I've never actually seen the car, just a photograph of the VIN.
It's a long story.....like I said, I'm hopeful but not holding my breath....
Old 02-08-2021, 08:21 PM
limejudge69's Avatar
I owned a 69 Pontiac plant Judge. Found the build sheet on top of the gas tank, under the tar mat. VIN seq # started with 339***. This was the Limelight Green RAIII car I bought at Jim Bingham's place
The Following User Says Thank You to limejudge69 For This Useful Post:
Old 02-08-2021, 09:25 PM
Cool !
i remember the story on that car.
Did you make a scan or picture of the Builsdheet that you could share ?
We had not located any B.Sheets on 69 Baltimore cars either.
But not long ago a member found one on a Real Late production Baltimore GTO in the rear seat springs.
Old 02-13-2021, 12:51 PM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
I too have my 69 Pontiac plant Judge build sheet with the letters "TAC" written in black across it. Sequence is 338...Still very readable and I had it laminated many years ago. Didn't know what it was until I did some research. I found it under the tar mat on top of the gas tank. From what people have said that is where the Pontiac headquarters cars placed the build sheets.
The Following User Says Thank You to Ram Air IV Jack For This Useful Post:
Old 03-30-2021, 01:22 AM
Any Pontiac built 69 GTO could be a Judge since they only starting building A bodies at the home plant in April, long after judge production began.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 04-24-2021, 11:58 PM
Got the PHS...not a Judge...passed on the car. Dang.
Old 07-08-2021, 04:39 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Curious , if someone can post a picture and point to this firewall hole that judge's had regardless of any option.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 07-09-2021, 08:13 AM
1969 Ram Air 1969 Ram Air is offline
Firewall hole for ram air cable.
Name:	Ram Air Cable location firewall.jpg
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 07-09-2021, 08:55 AM
padgett's Avatar
padgett padgett is offline
Have also found sheets inside the rear seat.
Also been told that there were no RA/VOE cars in 70 because both used the same bracket/knob/hole.
Web Site
Old 07-09-2021, 09:04 AM
Brewster's Avatar
Brewster Brewster is offline
The hole means the car had Ram Air nothing more.
Old 07-09-2021, 09:57 AM
padgett's Avatar
Best and really only way to know is PHS documentation. Many people in and out of Pontiac worked hard to make it happen, Some are still around. Pontiac was ready to destroy old records.
Web Site
