Old 04-14-2021, 10:59 PM
rare4k's Avatar
rare4k rare4k is offline
Default Head ID without the numbers
Is there a way to figure out the head ID without the center numbers ? I can't make out this set that are on this motor I have.
Sent from my moto z3 using Tapatalk
Old 04-14-2021, 11:06 PM
4dblnkldude's Avatar
Looks like a 12 to me.
Old 04-15-2021, 02:45 AM
Joe's Garage Joe's Garage is offline
Default Agree, it looks like a '1 2' casting
What's the block casting and engine code?
I really hate rust......
Old 04-15-2021, 02:47 AM
Kenth's Avatar
Kenth Kenth is offline
Date and rocker studs, threaded or pressed would be a start.
Agree with 4dblnkldude, looks like #12.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-15-2021, 02:46 PM
grandam1979 grandam1979 is offline
Date code on heads?
Old 05-16-2021, 03:22 PM
rare4k's Avatar
Looks like F 24 9
Old 05-17-2021, 03:15 AM
Kenth's Avatar
No Ram Air heads used oil shields on valve springs from factory.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 05-17-2021, 09:39 AM
rare4k's Avatar
These do not have oil shields on them FYI
Old 05-17-2021, 10:50 AM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
If they are 69 heads most likely they are 62's
Old 05-17-2021, 06:15 PM
Brewster's Avatar
Brewster Brewster is offline
Yeap, Looks like an E for May 24, 1969 #62 heads is my guess too. Do the two two codes match? What is the block and intake codes to compare with???
Old 05-17-2021, 07:36 PM
rare4k's Avatar
Not a E date code a F 24 code took them to a machine shop they cc the heads at 72
