Old 06-27-2021, 02:42 PM
ZnbOlds455's Avatar
ZnbOlds455 ZnbOlds455 is offline
Default 65 Accelerator Pedal Help
I cannot find a replace accelerator pedal link for my '65 GTO. The original had a roller that was completely worn and would not work well with the pedal. It's a horrible grinding feeling because it's metal-on-metal right now. Does anyone know if there's a suitable replacement? It's the circled items in this photo. Thanks in advance.
Old 06-28-2021, 09:33 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
I have this one. It's the original to my car. I found a nicer one years ago. The only problem with this one is it has a flat spot and you can sometimes feel it when driving. It doesn't always spin, but better than metal grinding.
ID:	568938   Click image for larger version
Old 06-28-2021, 09:36 AM
chrisp chrisp is offline
I have excellent replacement rollers for that problem.
Old 06-28-2021, 01:40 PM
ZnbOlds455's Avatar
chrisp, are you selling replacement rollers only? How does that work since the roller shaft is pressed into the accelerator rod? It looks like the rod would need to be modified to allow replacing the actual roller.
Old 06-28-2021, 06:22 PM
Yes & no modification is needed.
Old 07-02-2021, 07:56 AM
2 left .
Old 07-07-2021, 06:27 PM
ZnbOlds455's Avatar
I managed to design a replacement that my employer's machine shop made for me. I'll probably tweak the design a little in the future, but it'll do.
Old 07-07-2021, 08:27 PM
Old Goat Racer's Avatar
Because my 65 floorboard was rusted out where the gas pedal sits on 2 studs. I put a 67 GTO "floating pedal" on my car.
Been there for almost 40 years. Works for me.
Everybody knows somthin.
Nobody knows everything !
Thread Tools
Display Modes
